JohnC Posted June 29, 2007 Report Posted June 29, 2007 Hi, This house is new construction. The vinyl siding around the windows have a lot of gaps around vertical portions of the windows. Shouldn't these windows have J channels around them to help divert water? Image Insert: 69.23 KB Thanks, John C
hausdok Posted June 29, 2007 Report Posted June 29, 2007 Not if they're specifically designed for vinyl siding with a integral channel at the sides. I can see the accessory receiver at the bottom, what did they have at the top of the window? OT - OF!!! M.
chicago Posted June 29, 2007 Report Posted June 29, 2007 Hi john here is a good link also. see page twenty on the PDF. http://www.vinylsiding.org/publications ... nglish.pdf
JohnC Posted June 29, 2007 Author Report Posted June 29, 2007 Mike, I believe the top had something very similar to what you see on the bottom. I am going back to the house Sunday or Monday so Iââ¬â¢ll take another look up top. Still it looks like a crappy trim job around some of these windows. John C Originally posted by hausdok Not if they're specifically designed for vinyl siding with a integral channel at the sides. I can see the accessory receiver at the bottom, what did they have at the top of the window? OT - OF!!! M.
