John Dirks Jr Posted June 26, 2007 Report Posted June 26, 2007 I know FRP was used in common break walls. Was it also regularly used as sheathing across the entire roof?
Jerry Simon Posted June 26, 2007 Report Posted June 26, 2007 Fire-retardant plywood. And, yes, it was used for roof decking. As I recall, a bunch of defective FRT was found in Florida years back. http://www.housemaster.com/pdf/guide28.pdf
John Dirks Jr Posted June 26, 2007 Author Report Posted June 26, 2007 Actually a good question Les. I was wrong with FRP. I meant to say FRT. I second the motion on the thanks Jerry. Thanks for putting up the link too. Good info there.
randynavarro Posted June 27, 2007 Report Posted June 27, 2007 Yea, I believe FRP actually stands for fiberglass reinforced panels--the stuff you see in industrial bathroom walls. They can just use a hose to spray off the walls.
