CheckItOut Posted June 17, 2007 Report Posted June 17, 2007 Is a large pull block considered a main disconnect? This 1962 house had one panel and it did not have a throw for disconnect. I'm guessing that if you pull this there would be an opening ripe for fingers to get shocked. Would post a photo but something keeps telling me to log in.
CheckItOut Posted June 18, 2007 Author Report Posted June 18, 2007 Forgot to mention it is an ITE. You likely already knew that.
Jim Katen Posted June 18, 2007 Report Posted June 18, 2007 Originally posted by CheckItOut Is a large pull block considered a main disconnect? Yes, certainly. This 1962 house had one panel and it did not have a throw for disconnect. I'm guessing that if you pull this there would be an opening ripe for fingers to get shocked. That's unlikely. When you pull out the fuse block, there'll be a bakelight case behind it that covers the knife-slot connectors and makes it difficult to inadvertently touch them. Here are some pictures of an old Walker-ITE design that might be close to the one you saw. - Jim Katen, Oregon Image Insert: 55 KB Image Insert: 70.82 KB Image Insert: 73.12 KB
chicago Posted June 18, 2007 Report Posted June 18, 2007 If that is the old catridge fuse pullout,I can understand were he might be a little freaked out not being used to it. Those things show off a little spark at times that can take getting used to.When I was young I would pull them off with with rubber handle channel locks.This was so I could change cartridges for the elevators.
CheckItOut Posted June 18, 2007 Author Report Posted June 18, 2007 Thanks Bob. The pullout looks identical to that one I saw but this one had more conventional breakers.
Jim Katen Posted June 18, 2007 Report Posted June 18, 2007 Originally posted by CheckItOut Thanks Bob. The pullout looks identical to that one I saw but this one had more conventional breakers. If you can figure out how to make it work, I'd love to see pictures of a non-pushmatic-style ITE panel from 1962. -Jim Katen, Oregon
hausdok Posted June 18, 2007 Report Posted June 18, 2007 Email me the pictures and I'll insert them into the initial post for you. ONE TEAM - ONE FIGHT!!! Mike
