Chris Bernhardt Posted June 15, 2007 Report Posted June 15, 2007 Would you write up stripped screws in hinges on doors in new construction even if the hinges were not loose and the door was otherwise hung properly? It's not that I try every screw, but I have noticed that if a screw isn't properly seated in the hinge it's almost always stripped out in the jamb. Chris, Oregon
hausdok Posted June 15, 2007 Report Posted June 15, 2007 I write them all the time. If it's stripped on a brand new door, they're probably all over-tightened and all of them will loosen sooner or later. OT - OF!!! M.
