randynavarro Posted June 6, 2007 Report Share Posted June 6, 2007 Is this OK? Can't find any code references, nor do I have any pipe mfr's tech guides. Link to comment Share on other sites More sharing options...
hausdok Posted June 6, 2007 Report Share Posted June 6, 2007 Souldn't be a problem as far as I know. OT - OF!!! M. Link to comment Share on other sites More sharing options...
randynavarro Posted June 7, 2007 Author Report Share Posted June 7, 2007 So not many responses. . . Is this one of those amazingly simple, rudiementary items that anybody should know and everyone is too afraid to say, "Wow, Randy, you're really stupid for not knowing that its perfectly okay for PVC to touch concrete!" C'mon, I can take. I can take it. . . I'm ready. . . Link to comment Share on other sites More sharing options...
Bill Kibbel Posted June 7, 2007 Report Share Posted June 7, 2007 The only issue I'm aware of is when passing through a foundation or footing. Any drain/waste/soil pipe then needs a pipe sleeve (2 sizes larger) or a relieving arch. Link to comment Share on other sites More sharing options...
Jim Katen Posted June 7, 2007 Report Share Posted June 7, 2007 Originally posted by randynavarro So not many responses. . . Is this one of those amazingly simple, rudiementary items that anybody should know and everyone is too afraid to say, "Wow, Randy, you're really stupid for not knowing that its perfectly okay for PVC to touch concrete!" C'mon, I can take. I can take it. . . I'm ready. . . Well, I'd cheerfully berate you but I don't know what you mean by "PVC drain in direct contact with concrete." Is it embedded in concrete as if passing through a foundation wall? Is it lying on top of concrete? Is the end of the drain hard-pressed against the concrete? Etc, etc. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
MMustola Posted June 7, 2007 Report Share Posted June 7, 2007 I have never seen it installed any other way than in direct contact with concrete. In my area the sewer lines and drain pipes are installed before the basement floor is poured. The concrete is just poured around the pipes. I have never seen the pipe sleeved, wraped, or protected in any way. Every house built after 1970 in mid-michigan in plumbed with PVC waste piping and I have never seen a problem because of the direct contact with concrete. Link to comment Share on other sites More sharing options...
Les Posted June 7, 2007 Report Share Posted June 7, 2007 Randy, I just can't believe you did not know that!! Are you really an inspector? HAPPY NOW????? Truth be told - I never thought of it and really did not want to be a part of answering you and being wrong. There are those out there that would jump at another chance to prove me wrong! They are everywhere! Everywhere! Link to comment Share on other sites More sharing options...
randynavarro Posted June 8, 2007 Author Report Share Posted June 8, 2007 Well, I'd cheerfully berate you but I don't know what you mean by "PVC drain in direct contact with concrete." Is it embedded in concrete as if passing through a foundation wall? Is it lying on top of concrete? Is the end of the drain hard-pressed against the concrete? Etc, etc. - Jim Katen, Oregon Download Attachment: PVCStack.JPG 20.11 KB Link to comment Share on other sites More sharing options...
randynavarro Posted June 8, 2007 Author Report Share Posted June 8, 2007 Originally posted by MMustola I have never seen it installed any other way than in direct contact with concrete. In my area the sewer lines and drain pipes are installed before the basement floor is poured. The concrete is just poured around the pipes. I have never seen the pipe sleeved, wraped, or protected in any way. Every house built after 1970 in mid-michigan in plumbed with PVC waste piping and I have never seen a problem because of the direct contact with concrete. Thanks Mark. I think I learned somewhere in the distant past that they needed to be sleeved with something. Maybe it was only to keep the power trowels from gouging the pipe during the concrete finishing and has nothing to do with corroding the plastic. Link to comment Share on other sites More sharing options...
lars53 Posted June 8, 2007 Report Share Posted June 8, 2007 I usually only see them sleeved if they penetrate the foundation wall horizontally. This one is ABS. Sorry Can't get link to work. I upload it but it won't appear on the post?? Link to comment Share on other sites More sharing options...
chicago Posted June 8, 2007 Report Share Posted June 8, 2007 You pegged it Randy,I thought it was a trick question myself as there should be no dissimilar material type of problem. I'm guessing you do not see it done this way much in your area Link to comment Share on other sites More sharing options...
randynavarro Posted June 8, 2007 Author Report Share Posted June 8, 2007 Nope. Its mostly all ABS and on the older homes, cast iron. Link to comment Share on other sites More sharing options...
hausdok Posted June 9, 2007 Report Share Posted June 9, 2007 Originally posted by lars53 I usually only see them sleeved if they penetrate the foundation wall horizontally. This one is ABS. Sorry Can't get link to work. I upload it but it won't appear on the post?? Make sure that you resize it to less than 100Kb and that there are no blank spaces or special symbols, like parenthesis, in the name of the file. If you're on firefox or netscape, once the box tells you that it's uploaded, copy the URL out of the pop-up, close the window and then paste the URL into your post so that it will display. If you want it to display in line with the post, place img and /img in brackets where you want the photo to appear and cut and paste that portion of the URL that begins with "uploads" between the brackets and submit your post. Hope that helps. ONE TEAM - ONE FIGHT!!! Mike Link to comment Share on other sites More sharing options...
