ctgo4it Posted June 4, 2007 Report Share Posted June 4, 2007 As you can see from my other posts, I'm fairly new at this Home Inspection business. I don't have the cash to buy all the tools and gadgets I would love to. In what order of importance would you say I should buy tools, and which tools are the 'must haves' and which are just handy to have? I plan on buying one at a time as I can afford them. I'm not talking about screwdrivers, flashlight, camera etc, I mean moisture meter, CO detector, voltage meter etc. Thanks a lot Link to comment Share on other sites More sharing options...
Bob White Posted June 4, 2007 Report Share Posted June 4, 2007 Download Attachment: MXT.pdf 59.66 KB This tool is a must have for the successful HI, or the HI who wants to look successful.. Link to comment Share on other sites More sharing options...
Chad Fabry Posted June 4, 2007 Report Share Posted June 4, 2007 My preference would be Ladders, Camera, Suretest, Moisture meter. Anything else that costs more than a hundred can wait. 1 Link to comment Share on other sites More sharing options...
kurt Posted June 5, 2007 Report Share Posted June 5, 2007 Ladders, camera, 500,000 cpm spotlight, moisture meter, electric screwdriver, outlet tester/tic tracer. Link to comment Share on other sites More sharing options...
chicago Posted June 5, 2007 Report Share Posted June 5, 2007 Agree with the above,and might add a lasor measuring devise for the client to use while you are busy. They can be had for as little as $10.00. Get a good ratchet screwdriver and you can keep the rechargable in the truck. Link to comment Share on other sites More sharing options...
ctgo4it Posted June 11, 2007 Author Report Share Posted June 11, 2007 A ratchet screwdrivers is a good idea. Thanks Since I already have ladders, flashlights, a camera, outlet tester and various screwdrivers, I'm going to be looking into moisture meters. Anyone have any preferences / opinions on which one to get? Thank you Link to comment Share on other sites More sharing options...
hausdok Posted June 11, 2007 Report Share Posted June 11, 2007 Do a search for moisture meters and you'll probably find a dozen discussions on that topic - one of them within the past few weeks. There's a lot of stuff in the archives here. That's the first place you should go when you want to get info and the search feature works pretty nicely now. ONE TEAM - ONE FIGHT!!! Mike (Sometimes Editor of this joint) Link to comment Share on other sites More sharing options...
Chad Fabry Posted June 11, 2007 Report Share Posted June 11, 2007 Agree with the above,and might add a lasor measuring devise for the client to use while you are busy.They can be had for as little as $10.00. I hate to be so picky but one can buy ultrasonic measuring devices that have laser pointers for around ten to twenty bucks. The actual laser measuring devices are significantly more money. http://www.amazon.com/Stabila-LE100-Las ... 8&sr=1-115 Link to comment Share on other sites More sharing options...
SonOfSwamp Posted June 11, 2007 Report Share Posted June 11, 2007 Originally posted by ctgo4it As you can see from my other posts, I'm fairly new at this Home Inspection business. I don't have the cash to buy all the tools and gadgets I would love to. In what order of importance would you say I should buy tools, and which tools are the 'must haves' and which are just handy to have? I plan on buying one at a time as I can afford them. I'm not talking about screwdrivers, flashlight, camera etc, I mean moisture meter, CO detector, voltage meter etc. Thanks a lot My humble opinion: For indoor work, get a Streamlight rechargeable flashight. I've got one that's worked fine for over 10 years. Buy cheap ($20) rechargeables for crawl spaces. Any decent digital camera will do. (Disclosure: I hardly ever used a pic in a report. I used words. But that's just me.) We used no-pin Tramex Moisture Encounter meters ($300) for inside. We used a Delmhorst with pins (about $250) for outside & crawl space stuff. Speaking just for myself, I wouldn't go near a CO detector. I would not trust portable gas-testing equipment for life safety issues.I just wrote in every report: Install CO detector(s) per the manfucturer's instructions. Let First Alert or Nighthawk shoulder the liability for CO. Plus, CO detectors work 24/7, long after the HI is gone. The CO-detector recommendation will likely save more lives than a one-time CO check with a hand-held gizmo. IMHO, the SureTest is overkill. Few HIs, and even fewer electricians, understand the readouts, particularly voltage drop. SureTesting leads to endless arguments. Buy a cheap 3-light tester, and spend the $300 on a Little Giant ladder. If you can type and compose on the fly, get a decent laptop, so you can at least start your reports while you're still at the house. WJ Link to comment Share on other sites More sharing options...
hausdok Posted June 11, 2007 Report Share Posted June 11, 2007 To answer your question about moisture meters. I use a Protimeter Surveymaster, vintage 1999. I dropped it 4ft. last week and dislodged another component off the circuit board. Didn't have any superglue or anything available to glue it back in place so I could finish the job, so I took a wad of toilet paper and closed it up between the case and the circuit board and voila'! it was working again. The next day, I happened to be onsite the same time as a guy from a local environmental testing lab was there. He had one of the new GE branded Protimeter Surveymasters with the more nicely rounded case. We compared mine against his. Without bothering to calibrate both, we were within 1-2% points of each other after 7 years of hard use and 4-5 $10 repairs, because I keep dropping the poor thing onto concrete. Here's the house from Saturday. Like the bat ears? The wall behind the dark sofa in the basement recreation room ranged from 22 - 64% moisture in the drywall, and nearly 90% in the baseboard. It was raining cats and dogs. The gutters outside were leaking, a rainbarrel next to the foundation at that side was overflowing and the concrete crocks around the foundation were clogged, backed up and overflowing next to the foundation. Everything looked great until I scanned that drywall and the Protimeter went nuts. Now they're contemplating whether they want to make an offer, knowing that there's moisture in that wall and that side of the basement likely has some nasty stuff growing all over the backside of the drywall. By the way, there was another inspector onsite the same time as I. I didn't see him using a moisture meter and he left after an hour. I was there 3-1/2. I'm wondering if his clients are planning to make an offer, and, if they are, do they know about the drywall? Well, maybe he's reading this. ONE TEAM - ONE FIGHT!!! Mike Link to comment Share on other sites More sharing options...
Les Posted June 11, 2007 Report Share Posted June 11, 2007 The learned brethern have given you some good ideas. Me - Shoe covers, tums, tums, and more tums. Link to comment Share on other sites More sharing options...
hausdok Posted June 11, 2007 Report Share Posted June 11, 2007 Hey Les! To heck with those danged shoe covers. They are a pain to get on and off and they rip all the time. Yung and I each has a set of bedroom slippers that are clean as a whistle that we use for inside the house. They go on and off really easy. No wrestling with those stupid tyvek pieces of crap. OT - OF!!! M. Link to comment Share on other sites More sharing options...
Les Posted June 11, 2007 Report Share Posted June 11, 2007 Gotta have them imprinted with your company name and in various colors. Leave an extra pair on the kitchen counter beside the yo-yo. Link to comment Share on other sites More sharing options...
chicago Posted June 11, 2007 Report Share Posted June 11, 2007 One hour.My g-d it takes me three just for a Condo and they end up dragging me out through force.Just can't imagine how you could cover half the componants in that time. Link to comment Share on other sites More sharing options...
kurt Posted June 12, 2007 Report Share Posted June 12, 2007 Originally posted by Les Gotta have them imprinted with your company name and in various colors. Leave an extra pair on the kitchen counter beside the yo-yo. Mmmmmm-hmmmmmm. That makes me smile. Link to comment Share on other sites More sharing options...
StevenT Posted June 12, 2007 Report Share Posted June 12, 2007 Some basic things that I find useful are; Strap on headlamp - keeps my hands free Cheap plastic compass that is pinned to my shirt - enables me to locate and document where I am in the building. Lighted magnifying glass - to read difficult print Lighted headset magnifying visor - even more hands free examinations. Inspection mirror + lit magnifying glass = reading (or viewing) difficult things around corners. These items are all cheapies, but I can't tell you how happy I am to have them when the need arises. Which is quite often. By the way, I have given up trying to wrestle with shoe covers, but from working in hospitals, I discovered that the hair covers that are used easily slip on and off my shoes. They are made out of the same material as the shoe covers Link to comment Share on other sites More sharing options...
Jim Katen Posted June 12, 2007 Report Share Posted June 12, 2007 Toilet paper. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Les Posted June 12, 2007 Report Share Posted June 12, 2007 Remember - only one sheet per occurance! After use, you should always take it with you. You know, "Leave the house just like you found it". 1 Link to comment Share on other sites More sharing options...
randynavarro Posted June 12, 2007 Report Share Posted June 12, 2007 Will solve all of your footie headaches once and for all!! www.bootieshoecover.com I will never return to Tyvek, (at least for shoe booties). Link to comment Share on other sites More sharing options...
