Joe Tedesco Posted June 2, 2007 Report Posted June 2, 2007 Search for ROP and over 2600 will come up. This draft will be modified, based on ROC which are Comments to the Proposals, and many of them will change, so nothing is in concrete yet, that will be determined next week at the NFPA meeting in Boston, MA http://www.nfpa.org/assets/files/PDF/ne ... PDraft.pdf I understand that the new 2008 NEC will highlight the changes in the text of the NEC, and also include the ROP and ROC numbers for anyone who wants to find out the history of the proposed changes.
Jim Katen Posted June 2, 2007 Report Posted June 2, 2007 Originally posted by Joe Tedesco Search for ROP and over 2600 will come up. This draft will be modified, based on ROC which are Comments to the Proposals, and many of them will change, so nothing is in concrete yet, that will be determined next week at the NFPA meeting in Boston, MA http://www.nfpa.org/assets/files/PDF...08ROPDraft.pdf I understand that the new 2008 NEC will highlight the changes in the text of the NEC, and also include the ROP and ROC numbers for anyone who wants to find out the history of the proposed changes. That link doesn't seem to work. Did you mean this one: http://www.nfpa.org/assets/files/PDF/RO ... e1-200.pdf - Jim Katen, Oregon
Joe Tedesco Posted June 2, 2007 Author Report Posted June 2, 2007 Sorry, I fixed the link and changed it above as follows: http://www.nfpa.org/assets/files/PDF/ne ... PDraft.pdf Your link is for part of the ROC, all of which can be found here: http://www.nfpa.org/categoryList.asp?categoryID=611
