Terence McCann Posted June 1, 2007 Report Posted June 1, 2007 What would the building material typically be on the outside wall, under grade, when the inside is Bell tile/Structral Teracotta?
Jim Katen Posted June 2, 2007 Report Posted June 2, 2007 Originally posted by Terence McCann What would the building material typically be on the outside wall, under grade, when the inside is Bell tile/Structral Teracotta? I don't know about Ohio, but in Oregon it would be a parge coat of portland cement plaster. - Jim Katen
Terence McCann Posted June 2, 2007 Author Report Posted June 2, 2007 The tile in this basement was really no more than 4" deep. The basement has seen extreme moisture for years, the finished side of the tile is crumbling, and there are area's that have just fallen off. It is hard to imagine that this is the only foundation material.
Jim Katen Posted June 2, 2007 Report Posted June 2, 2007 Originally posted by Terence McCann The tile in this basement was really no more than 4" deep. The basement has seen extreme moisture for years, the finished side of the tile is crumbling, and there are area's that have just fallen off. It is hard to imagine that this is the only foundation material. I've never seen clay tile that small. Might their be two wythes? - Jim Katen, Oregon
Bill Kibbel Posted June 2, 2007 Report Posted June 2, 2007 I've never seen <8" thickness used for foundations. In fact, I've never seen <6" for load bearing walls, except when used as a backing for brick. 4" thickness or less would normally be used for partitions, where heat or sound insulation is desired. I've also seen 3.5" used for dividing flues in very large chimneys. Terry (or anyone else), I would love to have a pic of the stuff failing in my collection. I probably see more of this stuff than the average HI and it's always in good condition.
Terence McCann Posted June 3, 2007 Author Report Posted June 3, 2007 Bill, thank you very much. I'll try to make a special trip back to take more pics.
