jumpingjoeusa Posted May 15, 2007 Report Posted May 15, 2007 I have had experience with many panels but this is my first ITE and the breaker for the water pump has went bad and needs replaced. Where can I get any info on the removal of the breaker . It is a 220 VAC breaker. Any info would be appreciated. It is a pushmatic from like 1972. And are they readily available. Thank you
cguffin Posted May 15, 2007 Report Posted May 15, 2007 Do a google search on this. "ITE pushmatic breaker panel info" You will get lots of info.[] Thanks, Craig
Les Posted May 15, 2007 Report Posted May 15, 2007 Pushmatic breakers are not the typical screw and stab. If you question how to do it, might I suggest having an electrician do it. They are expensive and require a bit of skill to do properly.
Jim Katen Posted May 15, 2007 Report Posted May 15, 2007 Originally posted by jumpingjoeusa I have had experience with many panels but this is my first ITE and the breaker for the water pump has went bad and needs replaced. Where can I get any info on the removal of the breaker . It is a 220 VAC breaker. Any info would be appreciated. It is a pushmatic from like 1972. And are they readily available. Thank you Pushmatic breakers are readily available. They bolt onto the bus. Any electrician can do this for you for a minimal charge. - Jim Katen, Oregon
