Markinstin Posted April 19, 2007 Report Share Posted April 19, 2007 My answer is the one i give regularly Power Roof Exhauster, its never a bad answer it eliminates the problem of prevailing winds, it prevents the short circuiting that a ridge vent would cause and it really sucks ... warm moist air that is! Link to comment Share on other sites More sharing options...
Brian G Posted April 19, 2007 Report Share Posted April 19, 2007 Um....what was the question? Brian G. Had to Ask [?] Link to comment Share on other sites More sharing options...
Neal Lewis Posted April 19, 2007 Report Share Posted April 19, 2007 And they use a lot of electricity and have been known to seize up and catch on fire! Link to comment Share on other sites More sharing options...
Chad Fabry Posted April 19, 2007 Report Share Posted April 19, 2007 :Originally posted by Chris Bernhardt In the past I might have said increase ventilation for example by installing gable venting. That I think is wrong advice. The only thing I can think of is to increase venting with a continuous roof vent and installing venting in each rafter bay. Is that sound advice? Or is that not likely to really work either? Usually I will see the mildew lighter or non-existent in the rafter bays with eave venting or only the north side etc. but in this case it appeared to evenly coat everywhere as if no venting is occuring and I could see daylight at the vents of the eaves. Chris, Oregon ProSpector Home Inspections Hi Mark, You almost had it right..click on the reply button, not the "new" button. Link to comment Share on other sites More sharing options...
