rthitoff Posted March 30, 2007 Report Share Posted March 30, 2007 I have come across some homes with spray on radiant barriers. I live in a 30 yr old doublewide in Houston Texas area. The insulation is not real good. I saw some tiny ceramic powdery type stuff at paint stores that you put in paint, and spray interior or exterior, and I was wandering if someone has had any experience with this stuff. Or any other suggestions. The light bill gets pretty high in the summer. Thanks Rick http://www.tcinspections.net Link to comment Share on other sites More sharing options...
chicago Posted March 30, 2007 Report Share Posted March 30, 2007 Hi Rick If you go to the attics and insulation forum you will find one titled (smoke and mirrors you decide ),that mike put out for members to read.Hopfully you will find this helpful. Link to comment Share on other sites More sharing options...
Nolan Kienitz Posted March 30, 2007 Report Share Posted March 30, 2007 Spray-in radiant barrier is very tough to make work with the effective numbers it talks about in brochures. Spray-on product must have a smooth surface and must be applied up to two coats to even approach a 70% effective rating. Most roof decking (bottom side in attic space) is "not" smooth. I can put you in contact with a manufacturer's rep , based in Houston who can provide you with some additional information. I can also put you in contact with a few inspectors in the Houston market who can also share data with you. Mean time take a look at: http://www.polar-ply.com Link to comment Share on other sites More sharing options...
tugyun Posted September 21, 2007 Report Share Posted September 21, 2007 Originally posted by Nolan Kienitz Spray-in radiant barrier is very tough to make work with the effective numbers it talks about in brochures. Spray-on product must have a smooth surface and must be applied up to two coats to even approach a 70% effective rating. Most roof decking (bottom side in attic space) is "not" smooth. I can put you in contact with a manufacturer's rep , based in Houston who can provide you with some additional information. I can also put you in contact with a few inspectors in the Houston market who can also share data with you. Mean time take a look at: http://www.polar-ply.com Link to comment Share on other sites More sharing options...
