dtontarski Posted March 21, 2007 Report Posted March 21, 2007 The panel's grounding electrode conductor is double tapped under the incoming neutral conductor terminal. How should I address this in my report? Further analysis & correction? (Yes - I realize the neutral conductors require individual terminals) Download Attachment: Double Tap.jpg 130.64 KB
hausdok Posted March 21, 2007 Report Posted March 21, 2007 Read your comment. Looks like you already did. Make a recommendation that an electrician correct it. OT - OF!!! M.
Jim Katen Posted March 21, 2007 Report Posted March 21, 2007 Originally posted by dtontarski The panel's grounding electrode conductor is double tapped under the incoming neutral conductor terminal. How should I address this in my report? Further analysis & correction? (Yes - I realize the neutral conductors require individual terminals) What's to analyze? Just recommend correction. - Jim Katen, Oregon
