kurt Posted February 12, 2007 Report Posted February 12, 2007 Thread drift, sort of..... I've seen fair amounts of solid & laminated bamboo, both natural & carbonized, over the last 3 years. It's a very pleasing Zen-like vibe. Incredibly hard. I have a giant bamboo kitchen cutting board; it's amazingly resistant to moisture damage & hacking from cleavers. Bamboo is spectacular flooring; I am not a fan of laminate flooring, but I might consider laminate bamboo. Very nicely renewable resource; stuff grows fast.
Richard Moore Posted February 12, 2007 Report Posted February 12, 2007 So it turns out the rep's undisclosed installation error was choosing his product! I've just put down about 600 sf of prefinished Brazilian cherry. I went with an engineered product from SunFloors. It's about 5/8" overall with 3/16 inch of actual wood. I went back and forth over solid, prefinished, etc, etc but ended up with this because it came in 5½" width, "solid plank" (I didn't want it to end up looking like Pergo), all pieces 82" long, and has no bevel (which I don't like the look of). Brazilian cherry (actually Jatoba) has the hardest index of any wood flooring out there, which helps if you have a large dog. It also happens to be drop dead gorgeous with a lot of "character" although, as it darkens quite a bit with UV, you need to hold off on the rugs for a while. This product came with a choice of glue-down or glue together (and float). I chose the latter over 1/8" cork as I had to do a lot of leveling on the second floor (ex attic) of my old house. I actually leveled with roofing felt and even some shingles. Made my own transitions. It wasn't cheap, but I guess you get what you pay for. Even without any bevel, I have zero ridges and very smooth joints. At least...so far! Gotta tell the maid to go easy with the mop.
Scottpat Posted February 12, 2007 Report Posted February 12, 2007 I inspected a new home a couple of weeks ago that had just had solid bamboo flooring installed. It is a great looking product, that I would have. The builder said that he can get it as cheap or cheaper than comparable quality wood flooring.
