JayneEVHI Posted October 11, 2019 Report Posted October 11, 2019 Oh, I get it now. Thank's Jim. This is a good thread for newbs like me, who are trying to learn more.
John Dirks Jr Posted October 24, 2019 Report Posted October 24, 2019 (edited) When looking at replacement windows in older houses you should always consider this; Many, if not most replacement window installers are not tearing the opening down to the original framed opening. Instead they are removing the inner components of a window and leaving the outer frame of that old window in place. They then install a new complete window including a new frame inside of the older existing frame. The result is a smaller window opening. So, if the older window was smaller than today’s egress requirements, this new replacement makes the condition worse. Edited October 24, 2019 by John Dirks Jr
Jim Katen Posted October 24, 2019 Report Posted October 24, 2019 53 minutes ago, John Dirks Jr said: So, if the older window was smaller than today’s egress requirements, this new replacement makes the condition worse. Unless you replace an old double-hung, single-hung, or sliding window with a new casement window, in which case, the open portion of the window is made substantially larger.
