This is a personal question for all the fireplace guru's.[:-bigmout My house has a Country Flame fireplace with the metal doors and glass inserts. The problem I have is after a few hours of use the glass inserts in the doors get so black I can't see the flame through the glass, I know if the unit is working right the doors should not get the buildup on them. This is a really good fireplace with blowers and duct work for using with the central unit, it kept my house warm last weekend when we had the cold spell. I use several different types of wood and all seem to get the (I assume)cresote buildup on the glasses. If someone can give me a clue as to something I can do short of raising my chimney another few feet I will send a box of Oklahoma mesquite chips for the grill or smoker.[:-party]
If the doors are left open would smoke back draft into the house? It the fire place getting combustion air from the outside or from the house? It sounds to me that It may not be venting properly. Have you checked the flue for partial blockage?
Most of the recent inserts are designed with an "air wash" system, that pulls air in near the doors and forces combustion gases away from the glass.
The air wash system might be blocked, incorrectly installed or air is leaking in from another source, altering the intended air flow.
Thanks Mark and Bill. Unless there is a flaming fire going in the fireplace it will backdraft when the doors are opened. Tha damper does not work but is wide open and I have looked for obstructions in the chimney but it appears to be in good condition. the doors have air control valves as part of the door, so I did not think the damper would be a problem. There is a handle to pull for outside air for combustion but I am not sure how it works, After the 5-8" of snow we are supposed to get this weekend I will let it cool off and clean it out and dive back in again and see what I can find. BTW this fire place is about 20m years old and the company that built it has changed owners and when I called the company I knew as much about firepalces as the person I contacted did.
Sounds like it might not be getting enough combustion air. You might want to learn how to operate the fresh air intake to improve the combustion. Also is the chimney high enough or far enough away from walls or other roof lines that could cause it to backdraft?
After what Scott said I found the fresh air intake has been sealed shut, Why I do not know. I did try an experiment this weekend the fireplace has a huge ash cleanout under the firebox, I propped the cleanout door slightly open and opened the cleanout in the floor of the firebox, that helped immensely, the doors did not get nearly as much cresote buildup as before. I will get in and clean out the fireplace and see why the intake air is sealed off. Also it still backdrafts when I open the doors to add wood. The height of the chimney is slightly above the roof line and barely 2' above the 10 foot distance. I have seen a vacu-cap that is supposed to increase the draft. Has anyone seen or used one of these and do they work. Thanks Again
wildwillie
  • 11 months later...
I've had a Country Flame fireplace in my home for many years now. The doors have never sealed completely, and I can't control the fire at all. I've can't get anything from the local agent. Any suggestions, ideas??
wildwillie
It's not creosote, it's just soot. Once you get the air intake cleared out and working properly it should work much better. In the meantime, it won't hurt too much to leave the ash door *slightly* propped open.
As for the backdrafting, have you tried cracking a window in the same room as the fireplace while the fire is burning? If you do this, does it solve the backdrafting problem? You might simply have slightly depressurized house.
Once you close the doors you have shut off the fire's primary source of combustion air. Any other provision in the firebox for combustion air will be insignificant compared to the front opening.
So you close the glass doors. Now air is going to rush into the firebox anyway it can which will create quite a disturbance and swirling of the combustion gases from the fire. The soot staining on the glass is the result of the interruption of the nature draft of the fire. Also, because the air flow has been reduced, creosote generation may be increased.
  • 1 month later...
It happens to me and I though it was the the fireplace door having the problem. Sounds like it is burning a bit dirty could be from lack of air or the flue is not drafting enough. but I agree this is a bit quick to have that amount of soot and it is not only on the glass it is all over that fire box and your venting.
