MMustola Posted December 6, 2006 Report Posted December 6, 2006 My friend is faced with a choice between a Goodman or Armstrong furnace. If the stats on each model are equal and he is comparing apples to apples, which furnace do you think is better in terms of quality and dependability?
Terence McCann Posted December 6, 2006 Report Posted December 6, 2006 Six of one, half dozen of the other. Both lower end furnaces. Trane or Carrier is a better way to go although they cost more.
Eric B Posted December 6, 2006 Report Posted December 6, 2006 If you value the friendship encourage him to spend a little more money as Terry indicated.
K Vander Warf Posted December 6, 2006 Report Posted December 6, 2006 It all depends on the installer, that can greatly effect the operation of a good unit. Goodman is low cost in part because they dont advertise while at the same time they have out sold every other brand in recent years. One problem with Goodman is that they stay behind the rest on new designs. The models they currently sell are pretty close to all other brands. As for Armstrong, I had an Armstrong gas pack that made it 26 years. It was still working great, I changed it out to save on gas bills. Does that say that Armstrong still builds a good system? Who knows, they all have a bad run of design flaws here and there. I always tell people to buy a brand that has a parts supplier in town because they all fail at some point. Nothing stops a Trane but UPS if you know what I mean.
sbrooten Posted December 7, 2006 Report Posted December 7, 2006 Armstrong appears to be the builders' furnace of choice in this area and appears to have been the first choice for several years. I can't say I see a lot of problems with them, 'cause I don't. On the other hand, this isn't a climate where a furnace gets a good test. If I was back in MN I'm not sure I'd be saying the same thing. Trane and Carrier were far more common there.
Terence McCann Posted December 7, 2006 Report Posted December 7, 2006 I have a Goodman in my condo due to the fact that it was builders choice as well. There's a big reason builders use Goodmans and Armstrongs, they're cheap and for a reason. In our condo association we have already replaced several units and they're only ten years old. I'm not against low price, just low quality.
Brian G Posted December 8, 2006 Report Posted December 8, 2006 The package heat pump I recently put on my old mo-bile home is a Rheem. The place I got it from had Rheem and Goodman. They liked Goodman and couldn't believe that I, a Goodman, wanted the Rheem instead. I don't know that much about Rheem, but I've read plenty about Goodman's being cheaply built. The first bill for a full month was down more than half from the same month last year, and I'm told it's doing a better job to boot. [:-angel] Brian G. Change Can Be Good [:-thumbu]
Chad Fabry Posted December 8, 2006 Report Posted December 8, 2006 I can't get past the fact that Terry lives in a condo. I didn't think he was that old...
K Vander Warf Posted December 8, 2006 Report Posted December 8, 2006 In regard to cabinet design and construction the Rheem and Goodman are actually very close. The Rheem may have more updated components,however; if the Goodman has a scroll, it's probably a pretty good unit. The same goes with Goodman furnaces, they were the last to get rid of the clam shell heat exchanger. Therefore they had a lot of cracked exchangers while others did not. I think they have finally gone with a tubular design. You can save a buck or 2 with Goodman and get pretty good service out of it. But you've gotta do your home work and know what your getting as far as the design.
kurt Posted December 8, 2006 Report Posted December 8, 2006 I may be blind but..... Within any particular price point & efficiency rating, all the furnaces are about the same.
Brian G Posted December 8, 2006 Report Posted December 8, 2006 Originally posted by K Vander Warf The Rheem may have more updated components,however; if the Goodman has a scroll, it's probably a pretty good unit. Actually that was a factor, but it was the Rheem that had the scroll. Hell I just hope it matches the one I replaced for durability. 36 years is pretty damn good. Brian G. Scrollin', Scrollin', Scrollin, Keep That Heat a-Rollin', Rawhhhiiiiiddde! [:-cowboy]
Terence McCann Posted December 8, 2006 Report Posted December 8, 2006 Quote Originally posted by Chad Fabry I can't get past the fact that Terry lives in a condo. I didn't think he was that old... Eh? What was that sonny?
