hausdok Posted March 8, 2007 Report Share Posted March 8, 2007 Hi Bonnie, You've got quite the mystery there. 2000 gallons a day is a lot, that's for sure. However, I once got a call back from a couple that their water bill was high and they insisted that I must have missed a water leak under their home. I went back, checked the meter and found it spinning like crazy. I crawled under the home and found it dry as a bone. I then walked the front yard. It too looked dry and was very firm. I did notice a slightly darker area of the yard, though, and suggested that we find out whether there was a water leak there. He got a couple of shovels from the garage and we commenced digging. About 5 minutes later and at a depth of just over two feet, we still couldn't see any leak and were about to give up. I said, "Let's just go another shovel or two," and took one more shovelfull of dirt out of that hole. That's when a small thin stream of water shot about 6ft. in the air. We'd been within 6 inches of that leak and still hadn't detected it! To this day, I think it was just dumb luck that we found it, because the yard wasn't really that much darker - certainly probably not dark enough to have caused a water detection pro to have suspected a leak. OT - OF!!! M. Link to comment Share on other sites More sharing options...
Bonnie Trenga Posted March 8, 2007 Report Share Posted March 8, 2007 Hubby's Response: The strangest thing is that we're not going through the anywhere near the water volume that we did last month: 600 gallons/day versus 2000. I guess something could have moved to block the leak and slowed it down. Also, I think weââ¬â¢ve eliminated a deep line as the source since itââ¬â¢s not in the line from the main to the house, itââ¬â¢s in the sprinkler system. Those sprinkler pipes just arenââ¬â¢t that deep and it sure would seem like youââ¬â¢d see dampness at the surface at a minimum. Originally posted by hausdok Hi Bonnie, You've got quite the mystery there. 2000 gallons a day is a lot, that's for sure. However, I once got a call back from a couple that their water bill was high and they insisted that I must have missed a water leak under their home. I went back, checked the meter and found it spinning like crazy. I crawled under the home and found it dry as a bone. I then walked the front yard. It too looked dry and was very firm. I did notice a slightly darker area of the yard, though, and suggested that we find out whether there was a water leak there. He got a couple of shovels from the garage and we commenced digging. About 5 minutes later and at a depth of just over two feet, we still couldn't see any leak and were about to give up. I said, "Let's just go another shovel or two," and took one more shovelfull of dirt out of that hole. That's when a small thin stream of water shot about 6ft. in the air. We'd been within 6 inches of that leak and still hadn't detected it! To this day, I think it was just dumb luck that we found it, because the yard wasn't really that much darker - certainly probably not dark enough to have caused a water detection pro to have suspected a leak. OT - OF!!! M. Link to comment Share on other sites More sharing options...
Scottpat Posted March 8, 2007 Report Share Posted March 8, 2007 It could be a bad meter. To pump out 2000 gallons a day, you would have to see or hear it. That is around a gallon and a half a minute. Link to comment Share on other sites More sharing options...
Jim Katen Posted March 9, 2007 Report Share Posted March 9, 2007 Originally posted by Bonnie Trenga Hubby's Response: The strangest thing is that we're not going through the anywhere near the water volume that we did last month: 600 gallons/day versus 2000. I guess something could have moved to block the leak and slowed it down. Also, I think weââ¬â¢ve eliminated a deep line as the source since itââ¬â¢s not in the line from the main to the house, itââ¬â¢s in the sprinkler system. Those sprinkler pipes just arenââ¬â¢t that deep and it sure would seem like youââ¬â¢d see dampness at the surface at a minimum. I suppose you've ruled out the possibility that the meter was leaking a smaller amount for many months while the water company, instead of actually reading the meter, averaged your use and was simply charging you for what they *thought* you were using? - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Bonnie Trenga Posted March 9, 2007 Report Share Posted March 9, 2007 Well, the water company stands by its reads, so I guess they actually did read the meter. Perhaps one month they misread one digit so the usage seemed really high one month? Originally posted by Jim Katen Originally posted by Bonnie Trenga Hubby's Response: The strangest thing is that we're not going through the anywhere near the water volume that we did last month: 600 gallons/day versus 2000. I guess something could have moved to block the leak and slowed it down. Also, I think weââ¬â¢ve eliminated a deep line as the source since itââ¬â¢s not in the line from the main to the house, itââ¬â¢s in the sprinkler system. Those sprinkler pipes just arenââ¬â¢t that deep and it sure would seem like youââ¬â¢d see dampness at the surface at a minimum. I suppose you've ruled out the possibility that the meter was leaking a smaller amount for many months while the water company, instead of actually reading the meter, averaged your use and was simply charging you for what they *thought* you were using? - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Bonnie Trenga Posted March 12, 2007 Report Share Posted March 12, 2007 I checked the ASHI site and the deadline for speaker proposals has passed. That's a shame. How many inspectors attend such a conference? What other ones might be possible? Originally posted by kurt Originally posted by Bonnie Trenga I have to say very good on those rewrites. "The recommendation of" is what's called a nominalization, and it sets you up for a weak, vague and wordy sentence. These problems are some of the ones my book addresses. I bet inspector reports are full of nominalizations! Keep an eye out and then rewrite each sentence so it has a specific subject (who is doing the action) and a verb that is not blah (a verb like "to be" is dull). When you have a clear subject and a strong verb, you'll impart more information, and you'll have a less wordy, more readable sentence. You bet right. "It is a recommendation of this inspector that you blah, blah, blah....." Is that what you mean about nominalization? You should teach a report writing class @ one of the home inspection conferences. ASHI's is next January in New Orleans. Interested? Link to comment Share on other sites More sharing options...
Jim Katen Posted March 12, 2007 Report Share Posted March 12, 2007 Originally posted by Bonnie Trenga I checked the ASHI site and the deadline for speaker proposals has passed. That's a shame. How many inspectors attend such a conference? What other ones might be possible? Other national groups that host conferences include NAHI, NACHI and AII. A large private training school, ITA, also hosts a well-regarded conference each year. ASHI's, however, is the largest and most prestigious. I think they get about 1,500 attendees each year. Deadline or not, if you put together a well-organized outline they might still be interested in hearing from you -- if not for next year, then for the year after. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Bonnie Trenga Posted March 14, 2007 Report Share Posted March 14, 2007 I'm waiting to hear back from them on that. Also, I was thinking of pitching an article to ASHI Reporter. Link to comment Share on other sites More sharing options...
kurt Posted March 14, 2007 Report Share Posted March 14, 2007 Pitch away. The Reporter desperately needs professionally written articles. Also, I'll put in a word for the ASHI conference, not that I carry any weight, but I've got a couple "friends" that do. Link to comment Share on other sites More sharing options...
Jim Katen Posted March 15, 2007 Report Share Posted March 15, 2007 Originally posted by Bonnie Trenga I'm waiting to hear back from them on that. Also, I was thinking of pitching an article to ASHI Reporter. I'm on the Technical Committee that reviews articles for publication in the Reporter. We'd love it if you could submit an article or even a series of articles. Send a proposal to Sandy Bourseau at sandyb@ashi.org Tell her I sent you. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Bonnie Trenga Posted March 15, 2007 Report Share Posted March 15, 2007 Excellent. I will do that! Originally posted by Jim Katen Originally posted by Bonnie Trenga I'm waiting to hear back from them on that. Also, I was thinking of pitching an article to ASHI Reporter. I'm on the Technical Committee that reviews articles for publication in the Reporter. We'd love it if you could submit an article or even a series of articles. Send a proposal to Sandy Bourseau at sandyb@ashi.org Tell her I sent you. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Bonnie Trenga Posted March 16, 2007 Report Share Posted March 16, 2007 Well, the submissions deadline for the conference has passed and they can't consider a proposal anymore. Maybe next year. As for the ASHI Reporter, there's no budget for freelance writers. Darn. So, I guess that's a bummer. Doesn't mean we can't talk grammar and writing! Link to comment Share on other sites More sharing options...
Bill Kibbel Posted March 17, 2007 Report Share Posted March 17, 2007 Kurt and I were interviewed by a paid freelance writer for an article in the ASHI Reporter. Maybe the policy changed. Maybe that's why I don't read it any more. Link to comment Share on other sites More sharing options...
Scottpat Posted March 17, 2007 Report Share Posted March 17, 2007 Even if the deadline has passed for ASHI, I would send it in. I served on the Education committee for several years and Chair of it for one year, we always had folks dropout and we needed to replace them. This happens every year. One of the reasons for the early deadline is due to all of the individual states and their approval process. It takes months to get some states to approve the education for a national conference. Send them in!! Send them to Michael Long at ASHI. It is really not too late. Now keep in mind that they also get around 75 to 100 submittals every year and they can only use around 30 of them. The 2 hour sessions are used the most. Hint, hint! Link to comment Share on other sites More sharing options...
Bonnie Trenga Posted March 17, 2007 Report Share Posted March 17, 2007 Mr Long himself told me no, so that seemed like a pretty firm no. I will definitely consider doing it the next year. Link to comment Share on other sites More sharing options...
Bonnie Trenga Posted March 17, 2007 Report Share Posted March 17, 2007 I guess I'm a wuss. I'll contact Mr Long again to see if I can convince him to let me do a two-hour presentation. Originally posted by ozofprev I know you're too nice to say anything Bonnie, but I really think that's ignorant. The author of such a cool book on a subject so important to this 'profession', being dismissed this early can only be the result of the lazy bureaucratic stagnation that's going to kill a great organization (society). Shame, Mr. Long! Originally posted by Bonnie Trenga Mr Long himself told me no, so that seemed like a pretty firm no. I will definitely consider doing it the next year. Link to comment Share on other sites More sharing options...
Bonnie Trenga Posted March 17, 2007 Report Share Posted March 17, 2007 I hope my proposal will be accepted. Jim, can you tell me how many people might attend my presentation? Do I do one presentation only and then leave, or do I do one each day and have a booth and all that? It's an exciting prospect. Link to comment Share on other sites More sharing options...
Les Posted March 17, 2007 Report Share Posted March 17, 2007 Bonnie, Typically you would have 100-300 at your type of presentation. However, it has been my experience that you may have more. This is a topic that cuts across all levels of the inspection business. You can have a "booth" but that will cost ya! Scott and I worked the education circuit for several years with ASHI. You would be very well received. ASHI education is not just letting someone off the street talk for a few hours and then give the attendees continuing education credits. The presentations must be meaningful and all are proctored by ASHI committee members and evaluated. They have done a wonderful job of providing actual education not propoganda. There have been exceptions. Do not think ill of Mike, he has a job to do and does it quite well. I would suggest contacting the Chairman of the ASHI Education committee and telling him you come with some high "recommendations" from Katen, Patterson, VanAlstine,Mike, etc. I will be pleased to contact him on your behalf. Link to comment Share on other sites More sharing options...
Bonnie Trenga Posted March 17, 2007 Report Share Posted March 17, 2007 Hi. I was going to finalize my proposal by Monday in the interest of time. Perhaps I could fax it to you or another guy with some pull instead, and then you could hand it to the appropriate people. Or I could send it to Mr Long as I was originally planning, and see what happens. Whatever you think. At this point I haven't come up with a very detailed outline, but I basically want to teach chapters out of my book. I was thinking of having copies of the book on hand, which would be available for less than cover price (something like 40% off). Originally posted by Les Bonnie, Typically you would have 100-300 at your type of presentation. However, it has been my experience that you may have more. This is a topic that cuts across all levels of the inspection business. You can have a "booth" but that will cost ya! Scott and I worked the education circuit for several years with ASHI. You would be very well received. ASHI education is not just letting someone off the street talk for a few hours and then give the attendees continuing education credits. The presentations must be meaningful and all are proctored by ASHI committee members and evaluated. They have done a wonderful job of providing actual education not propoganda. There have been exceptions. Do not think ill of Mike, he has a job to do and does it quite well. I would suggest contacting the Chairman of the ASHI Education committee and telling him you come with some high "recommendations" from Katen, Patterson, VanAlstine,Mike, etc. I will be pleased to contact him on your behalf. Link to comment Share on other sites More sharing options...
ozofprev Posted March 18, 2007 Report Share Posted March 18, 2007 Bonnie, I just want to follow through - I don't know Mr.Long. He could very well be a good guy. I always made sure to let my kids know when they did a bad thing, that did not make them bad people. I think Mike did a bad thing - that doesn't make him a bad person. Link to comment Share on other sites More sharing options...
Bonnie Trenga Posted March 18, 2007 Report Share Posted March 18, 2007 Thanks for your input. I'll put together an irresistible proposal for Mr Long. Link to comment Share on other sites More sharing options...
Bonnie Trenga Posted March 20, 2007 Report Share Posted March 20, 2007 Does anyone want to fix the spelling mistake in this topic's title?[:-graduat Link to comment Share on other sites More sharing options...
Brad Manor Posted March 20, 2007 Report Share Posted March 20, 2007 narrative [] Link to comment Share on other sites More sharing options...
Jesse Posted March 20, 2007 Report Share Posted March 20, 2007 I thought "righting" Link to comment Share on other sites More sharing options...
kurt Posted March 20, 2007 Report Share Posted March 20, 2007 Originally posted by Bonnie Trenga Does anyone want to fix the spelling mistake in this topic's title?[:-graduat Duh.... I forgot I was a moderator...... Fixed now. Link to comment Share on other sites More sharing options...
