Scottpat Posted February 15, 2004 Report Posted February 15, 2004 On another forum it has been discussed that NM cable (Romex) is not allowed for the connection of a kitchen disposal. Every single home that I have inspected has been connected with NM cable. Some I have noted, that the NM cable is in an area that it could be subject to damage, but I have never said that NM cable can not be used for the connection of the disposal. Should I be reporting that NM cable should not be used? HELP!
Renron Posted February 15, 2004 Report Posted February 15, 2004 Scott, Yes, unprotected nm cable,(romex)(it's a brand like kleenex) should be reported when it is exposed and suseptable to damage. People have the tendency to shove a myriad of things under the kitchen sink that could damage the nm cable. I find quite a few GD that do not have proper wire restraint devices either. In my area it is acceptable to have it (romex) exposed in the garage if it is located 7' or higher. Ron
chrisprickett Posted February 15, 2004 Report Posted February 15, 2004 Scott, In this area, the disposal has an appliance cord that is plugged into an outlet under the sink. It is shared with the dishwasher outlet. The disposal is wired on a "half hot", controlled by a switch. I've never seen one wired with NM.
Paul MacLean Posted February 15, 2004 Report Posted February 15, 2004 In Central Texas I see diposers wired with both NM Cable and cord & plug and that's about everything. I have never called out NM Cable or a cord if it's properly clamped to the disposer. Let's hear some other opinions.
hausdok Posted February 15, 2004 Report Posted February 15, 2004 Hi, They're connected with NM, MC and cord and plug here all the time. New homes are all cord with plug. I usually call NM because it is, as Douglas pointed out, typically not secured within one foot of the connection. Most of the time, it also doesn't have proper strain relief and on more than one occasion I've found the wiring taped up and arc/char marks on the disposal housing where the constant back and forth movement caused by shoving a trash can into the cabinet beneath the sink had caused the unrestrained cable to chafe through and short out. MC'S the same - no strain relief in about 90% of the cases. Another common thing here is to find the romex either connected to a plug and plugged into a receptacle beneath the sink or wired to a switch in an ungrounded metal box mounted just inside the cabinet door without a switch cover on it. Then there are the disposers wired with lamp cord without an equipment grounding conductor directly to a switch in an ungrounded metal box without the cover........ ONE TEAM - ONE FIGHT!!! Mike
Norm Posted February 15, 2004 Report Posted February 15, 2004 Douglas, Doesn't the UL, or other approved testing lab., list the disposal as an assembly which would include the electrical power cord? NORM SAGE
DLRambo Posted February 15, 2004 Report Posted February 15, 2004 Look in your code books - romex is not approved to be connected to a plug. Dan Bowers
hausdok Posted February 15, 2004 Report Posted February 15, 2004 Never said anything different. It's just one of the typically found loopy things around here that I write up. OT - OF!!! M.
Renron Posted February 15, 2004 Report Posted February 15, 2004 Douglas, Thanks for the explaination for the 7' off the floor rule. I always like knowing where and why these "rules" come from. I love this website. Please don't bail out on us Douglas......icons or not... we need your wealth of knowledge. Thanks. Ron
Richard Moore Posted February 16, 2004 Report Posted February 16, 2004 Here's the electrical connection instructions for Insinkerator disposals. http://www.prwebworks.com/insinkerator.pdf Not much help I'm afraid.
