tbowker Posted September 16, 2006 Report Posted September 16, 2006 I came across this a couple of days ago on a house that's 10 years old...this is the only vent stack on the house and it's completly sealed....would'nt you think that the interior would start smelling bad? Download Attachment: Ventcap.JPG 39.72 KB
fqp25 Posted September 16, 2006 Report Posted September 16, 2006 Maybe they want to trap and use sewrer gas as an alternative fuel source. Was there a washing macine gray box? Those usually suck the p-trap dry.
Erby Posted September 16, 2006 Report Posted September 16, 2006 Water will drain, but slowly and reluctantly with the sytem gurgling as it pulls air from other sources. I see that a lot around here in some of the newer developments (15 years newer??). Plumber just never went back and removed the cap after the pressure test.
