hausdok Posted September 7, 2006 Report Posted September 7, 2006 September 7, 2006; Release #06-252 WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed. Name of Product: Delta Performance or Delta Performance Plus Series Combination Water Heaters Units: About 3,000 Manufacturer: Triangle Tube/Phase III, of Blackwood, N.J. Hazard: The burner plate and flue hood seal on the water heaters can fail due to an improper seal causing a leak of flue gases and carbon monoxide (CO). This poses the risk of CO poisoning to consumers inside of the house. Incidents/Injuries: Triangle Tube has received one report of a flue leak with the recalled Combination Water Heater during installation. No injuries have been reported. Description and Models: The recalled Delta Performance or Delta Performance Plus Series Combination Water Heaters operate on natural or propane gas. The water heaters are white and rectangular. "Triangle Tube" is written on the silver-colored control panel. "Delta" is printed on the front of the water heater. The burner is located under a white or gray cover that protrudes outward at the bottom front of the heater. The models and serial numbers included in this recall are listed below. The model and serial numbers are located on the rating plate on either the front or the right side of the water heater. Models PG-25 PG-30 PG-35 PG-40 PG-45 PG Plus-25 PG Plus-30 PG Plus-35 PG Plus-40 PG Plus-45Serial Numbers1148 through 6203Sold at: Plumbing and heating wholesale companies to independent plumbing and heating contractors from August 2001 to January 2006 for about $3,500. Manufactured in: United States Remedy: Consumers should immediately stop using the recalled waterheaters and contact Triangle Tube to schedule a free repair. Consumer Contact: For more information, contact Triangle Tube at (800)856-6271 between 8 a.m. and 4 p.m. ET Monday through Friday, or visit the company's Web site at www.triangletube.com To view this release online, please go to our web site at:http://www.cpsc.gov/cpscpub/prerel/prhtml06/06252.html U.S. Consumer Product Safety Commission Office of Information and Public Affairs Washington, DC 20207 Firm's Recall Hotline: (800) 856-6271 CPSC Recall Hotline: (800) 638-2772 CPSC Media Contact: (301) 504-7908
