Terence McCann Posted August 16, 2006 Report Posted August 16, 2006 Inspected a house that had a wood burning fireplace that has been converted to gas logs. Also, sharing the same chimney is a forced hot air, wood burning add-on heating system (the original furnace is oil). Can the now gas fireplace, which use to be wood burning, share the same flue as the wood burning furnace? TIA
hausdok Posted August 16, 2006 Report Posted August 16, 2006 Hi, Don't think so. According to my CodeCheck HVAC: No solid fuel and gas in same vent......IRC 2426.5.7.1 and UMC 802.4 It's a few years old so the citation numbers could have changed but I doubt that the citation has. OT - OF!!! M.
Terence McCann Posted August 16, 2006 Author Report Posted August 16, 2006 Thanks Mike. What is the main reason for this rule?
hausdok Posted August 16, 2006 Report Posted August 16, 2006 This is just a guess, because I don't remember anyone explaining this to me, but in my mind the building science works. Woodburning stoves, fireplaces and appliances need a larger flue than gas-burning stoves, fireplaces and appliances. When the wood burning object isn't actually burning any wood, I should think that cold air trying to dive down that big flue could overcome the bouyancy of gas exhaust, because it's at such a low temperature, and cause the gas appliance to backdraft into the home through the woodburning appliance. Any 'sperts out there know if I'm even close? I gotta go. If nobody's answered with a better reason by the time I get back, I'll look it up. ONE TEAM - ONE FIGHT!!! Mike
Jim Katen Posted August 16, 2006 Report Posted August 16, 2006 Originally posted by hausdok This is just a guess, because I don't remember anyone explaining this to me, but in my mind the building science works. Woodburning stoves, fireplaces and appliances need a larger flue than gas-burning stoves, fireplaces and appliances. When the wood burning object isn't actually burning any wood, I should think that cold air trying to dive down that big flue could overcome the bouyancy of gas exhaust, because it's at such a low temperature, and cause the gas appliance to backdraft into the home through the woodburning appliance. . . That's all true. But in Terry's case, a set of gas logs in a fireplace designed for wood logs is going to be operating under those conditions anyway. I think the rationale for the rule is that wood-burning appliances create creosote and soot that can build up and narrow the flue or block it entirely. - Jim Katen, Oregon
