Focal Point Posted August 9, 2006 Report Share Posted August 9, 2006 First of all I have to apologize. I do not have any pictures so try to use your imagination... I am inspecting a late 60's early 70's ranch today. Nothing out of the ordinary, except when I get to the crawl, all I see is grey pipe, grey pipe as far as the eye can see... Now I know what your probably thinking, PB right? Think again! At first I assumed it was PB also until I took a closer look... Imagine my amazement when I read clear as day right across the pipe - PVC Exterior rated UV resistant Electrical Conduit! And miles of it! 1", 2" and 4", the entire waste system was constructed from Elect. Conduit! Even the A/C condensate line was made from this stuff. My next question is, well how bout it? Other than the fact that itââ¬â¢s grey, its still PVC right? Is it ok? Or should I write it up? And how? Link to comment Share on other sites More sharing options...
kurt Posted August 9, 2006 Report Share Posted August 9, 2006 Anyone dumb enough to do that is dumb enough to do all sorts of things. I'd be all over it in the report; too many goofy possibilities. That said, I'm pretty sure that it's all Schedule 40; it's just grey. Link to comment Share on other sites More sharing options...
Jim Katen Posted August 9, 2006 Report Share Posted August 9, 2006 Originally posted by Focal Point . . . 1", 2" and 4", the entire waste system was constructed from Elect. Conduit! Even the A/C condensate line was made from this stuff. My next question is, well how bout it? Other than the fact that itââ¬â¢s grey, its still PVC right? Is it ok? Or should I write it up? And how? Putting aside for a moment the fact that plumbing pipe and fittings are supposed to be listed or labeled to conform to approved standards for plumbing . . . The first thing that comes to my mind is that there are certain fittings necessary to a DWV system that are simply not manufactured in electrical conduit. Did you see any sanitary tees? How about wyes and combos? How did they handle horizontal changes in direction? Did you know that DWV fittings are manufactured with a 1/4" per foot slope? Electrical conduit fittings aren't. Look carefully at the system. I'll bet you a dollar that the system doesn't conform to accepted DWV practices. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Focal Point Posted August 9, 2006 Author Report Share Posted August 9, 2006 Yes. Tees, joints, elbows, the whole gambit. All of the conectors, wyes and Tees were standard PVC, glued and sealed, Solid as could be I assume regular pipe sealer will work, as it apearantly did. As I stated it "is" PVC. AS far as DWV I dont know. Link to comment Share on other sites More sharing options...
Jim Katen Posted August 9, 2006 Report Share Posted August 9, 2006 Originally posted by Focal Point Yes. Tees, joints, elbows, the whole gambit. All of the conectors, wyes and Tees were standard PVC, glued and sealed, Solid as could be I assume regular pipe sealer will work, as it apearantly did. As I stated it "is" PVC. AS far as DWV I dont know. So, in contrast to what you described in your initial post, the fittings were white PVC? - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Focal Point Posted August 9, 2006 Author Report Share Posted August 9, 2006 I apolagize, I should have been more clear. The "lines" were conduit. The fittings were not. Link to comment Share on other sites More sharing options...
Les Posted August 9, 2006 Report Share Posted August 9, 2006 As far as I know you can not effectively solvent weld pvc conduit and pvc plumbing. pvc conduit has different support specs, also it is not as photochemically reactive as pvc plumbing. Link to comment Share on other sites More sharing options...
Jim Katen Posted August 10, 2006 Report Share Posted August 10, 2006 Originally posted by Les As far as I know you can not effectively solvent weld pvc conduit and pvc plumbing. pvc conduit has different support specs, also it is not as photochemically reactive as pvc plumbing. It'll probably be fine but no one really knows because no one's done meaningful testing of these products in this application. Unconventional things behave in unconventional ways . . . - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Richard Moore Posted August 10, 2006 Report Share Posted August 10, 2006 Does PVC conduit weaken at higher hot water temperatures like regular PVC plumbing pipe? Do we care? No PVC (other than CPVC) is allowed for interior distribution plumbing by any code that I'm aware of. As Jim said, it probably will be fine, but then garden hoses would also probably work. Both are less than the minimum standards set by knowledgable people who likely actually tested those options, and increase the possibility of a flooded home. It's just wrong. I wonder if the homeowner is an electrician? Link to comment Share on other sites More sharing options...
Focal Point Posted August 10, 2006 Author Report Share Posted August 10, 2006 It's just wrong. I wonder if the homeowner is an electrician? I sure hope not, as the elect. furnace was set up on a 100 Amp breaker. The buyer (a friend of mine) just laughed when I told him he could run the entire home off of his furnace. (No I would not normally say that to a client) Link to comment Share on other sites More sharing options...
bandag Posted December 14, 2006 Report Share Posted December 14, 2006 Yeah, apparently the homeowner or his brother in law was a electrician and used what ever they had laying around. I would tell the buyer either plan on replacing the whole mess or every morning when he gets up head for the crawl space door and check for leaks. Link to comment Share on other sites More sharing options...
