Dayton Posted July 9, 2006 Report Share Posted July 9, 2006 GFCI receptacles can protect ordinary outlet downstream downhill to each side or uphill Link to comment Share on other sites More sharing options...
Jim Katen Posted July 9, 2006 Report Share Posted July 9, 2006 Originally posted by Dayton GFCI receptacles can protect ordinary outlet downstream downhill to each side or uphill What do you think? - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
homnspector Posted July 9, 2006 Report Share Posted July 9, 2006 This is actually a trick question. If you consider electricity as a stream, it must run downhill as a stream does, so both A and B may be true. Receptacles on either side of the GFCI receptacle can be protected by the receptacle. Physical positioning has nothing to do with how it is wired, so C may be true. A receptacle uphill of the GFCI receptacle can also be protected, assuming "uphill" is a physical position of the receptacle, so D may be true. Typical BS question with not enough information to make the correct choice. Obviously, the answer is E, all of the above. Link to comment Share on other sites More sharing options...
Brian G Posted July 9, 2006 Report Share Posted July 9, 2006 Originally posted by homnspector Obviously, the answer is E, all of the above. Yeah, what he said. [] Brian G. E Knows the Answer, E Does [] Link to comment Share on other sites More sharing options...
DonTx Posted July 9, 2006 Report Share Posted July 9, 2006 Funny that question should pop up. I surfed over to NACHI last night to see how much 'tougher' the entrance exam was, that question was on the first page. Link to comment Share on other sites More sharing options...
