homnspector Posted July 7, 2006 Report Posted July 7, 2006 I had a client ask me today why a laundry room (hall closet in this case) had to have a vent fan. I had a little trouble answering this. I said the obvious "high humidity" but he pointed out that the washer was a closed system and the dryer vented to the exterior. Any ideas why this is a code requirement?
randynavarro Posted July 7, 2006 Report Posted July 7, 2006 -I think a code requirement is a blanket statement that doesn't address specific and 'custom' installations. In this particular case, one might be able to make an argument that a vent is unnecessary -Not sure what a closed system is, but the washer and dryer will still generate heat which is still a good thing to vent, especially on a summer day -Fan is a good thing to have as inevitably the dryer vent duct will disconnect or get a hole and then you'll have warm, moist air inside the closet. Just some thoughts - good question, though. Makes you think!
Mike Lamb Posted July 7, 2006 Report Posted July 7, 2006 What's the reference that this is a requirement? With a gas dryer, it might present combustion and draft issues.
homnspector Posted July 7, 2006 Author Report Posted July 7, 2006 Hmmmm, good question. I assumed it was required because the Az standards require that we report the method of ventilation in the laundry area.
Les Posted July 7, 2006 Report Posted July 7, 2006 If I am understanding you correctly, you must report method of ventilation and not necessarily a mechanical ventilation fan? Much like a bathroom that has a window, but no powered vent fan? Dryers move a ton of air, so a combustion appliance would be problematic and an electric would also starve for air to load the water into. I think an inspector should always be aware of the air capacity of any space; bedrooms, utility rooms, bathrooms, furnace and water heater areas, etc.. Front loading washers are a closed system, but top loader are not. Have you ever sniffed nasty socks being washed? With front loaders, you do not smell anything. Professional sniffer that I am!
