peterk2 Posted June 7, 2006 Report Posted June 7, 2006 I inspected house a house a while back that had the fireplaces converted to natural gas. On one fireplace the supply line ( CSST ) was routed from the basement to the fireplace through the old ash dump. I didn't see anything wrong with this since the ash dump is basically a chase from the basement to the firebox. My client calls me to say that a plumber said it was not safe and he could fix it for $ 800.00. The client is not blaming me for anything, just wants some good advice. I think the plumber sees an $800 opportunity. Piping was properly installed in the firebox with a shut off, etc. Peter K Argyle Home Inspections
Les Posted June 7, 2006 Report Posted June 7, 2006 We have run across that several times. Here in Mid-Mich there are several jurisdictions that allow it and one that does not; That one requires iron pipe but you can use the chase. I don't see anything particularily wrong with the idea as long as there is a shut off outside the firebox. Again, some gurus don't even require that. $800 seems a little steep.
Jim Katen Posted June 8, 2006 Report Posted June 8, 2006 Originally posted by peterk2 . . . My client calls me to say that a plumber said it was not safe and he could fix it for $ 800.00. The client is not blaming me for anything, just wants some good advice. I think the plumber sees an $800 opportunity. Piping was properly installed in the firebox with a shut off, etc. Peter K Argyle Home Inspections Tell the client to ask the plumber to cite a code or reference to back up his assertion that it isn't safe. - Jim Katen, Oregon
