Mechanotherm Posted June 4, 2006 Report Share Posted June 4, 2006 I'm sure everyone here knows that with the new SEER ratings requirements, there are a lot of new condener units being installed. The problem I've found is that homeowners frequently insist on keeping the existing evaporator coils in place in their air handler. While I'm pretty good at explaining to homeowners why they really, really should replace all of it at one time, I'd like some suggestions on how to get the point across better (other than the obvious energy savings and the benefits of having "everything the same and matching"). Thank you in advance for your ideas! Link to comment Share on other sites More sharing options...
Scottpat Posted June 4, 2006 Report Share Posted June 4, 2006 How about telling them that it will not work properly. It is not installed to the manufacturers requirements. The warranty is most likely voided on a mismatched system. I would think that the above "one liners" should get the point across. Link to comment Share on other sites More sharing options...
DonTx Posted June 4, 2006 Report Share Posted June 4, 2006 I agree with Scott. I'm not going to try and beat a dead horse. Some people will not get one no matter what unless the unit goes out. I wouldn't lose sleep over the ones who are too stubborn to upgrade. Link to comment Share on other sites More sharing options...
homnspector Posted June 5, 2006 Report Share Posted June 5, 2006 How about " There is no sense in replacing 1/2 of the worn out, outdated equipment. Replace it now or replace it later" Link to comment Share on other sites More sharing options...
a46geo Posted June 5, 2006 Report Share Posted June 5, 2006 How about throwing good money after bad? Without a matched unit, you will not receive the SEER rating you just paid to have installed. I would be careful about any void warranty claims. I have never heard of any manufacturer doing that. That sounds like something from some shylock contractor. Link to comment Share on other sites More sharing options...
DonTx Posted June 5, 2006 Report Share Posted June 5, 2006 Home Warranty Companies will routinely void their warranty's for mis matched equipment. I've seen and heard it more than once. It's just another way they can get the premiums and refuse claims. Same goes for having breakers larger than what the manufacturer recommends. Link to comment Share on other sites More sharing options...
MechAcc Posted June 10, 2006 Report Share Posted June 10, 2006 At the last service meeting that I had the manufacturers rep stated that on future warranties on compressors that the model and serial number of the evaporator would also be required. That means that even the manufacturers are cracking down on the mismatches. Link to comment Share on other sites More sharing options...
