Bill Kibbel Posted May 15, 2006 Report Posted May 15, 2006 On Friday, I inspected a building that started out as a modest 1870s home. Multiple additions now connect the house with the barn at the back of the property. It now contains 5 apartments and an indoor parking garage. In one of the crawlspaces there was a large (approx 16'x18') internal brick foundation. I first thought it was a cistern, but found this in the kitchen of the apartment above. Any guesses? I know what the right one is for, but not the two on the left.
Bill Kibbel Posted May 15, 2006 Author Report Posted May 15, 2006 There was a large chimney above it.
homnspector Posted May 15, 2006 Report Posted May 15, 2006 What Rob said. Is that a damper control on the right of the door?
hausdok Posted May 15, 2006 Report Posted May 15, 2006 Let me correct my earlier post, Early central "radiant" heating system. The fire Burns and hot gases pass into the brick foundation through a maze of galleries and rise up through the chimney and out the roof. The thing you thought of as a cistern radiates heat up through the house. The romans had 'em, the Koreans still do, my first hooch in Korea was heated that way. You definitely have to keep a window cracked or you're liable to croak from CO that seeps up through the bricks below. OT - OF!!! M.
Inspectorjoe Posted May 16, 2006 Report Posted May 16, 2006 I'm going to go out on a short limb and say it's a plain ol' wood-fired wall oven. I saw some similar things a few months ago at Hancock Shaker Village in Massachusetts. If anyone is interested, here are some more pics I took there last President's Day. http://inspectorjoe.photosite.com/HancockShakerVillage
Jim Katen Posted May 16, 2006 Report Posted May 16, 2006 Originally posted by inspecthistoric. . . Any guesses? I know what the right one is for, but not the two on the left. When you open those two doors, what do you see? - Jim Katen, Oregon
Bill Kibbel Posted May 17, 2006 Author Report Posted May 17, 2006 "When you open those two doors, what do you see?" Behind the top left one was a very shallow space. Only a few plastic shopping bags fit in there. I couldn't get the left lower door open. The right door was actually only a hinged plate with a counter balance to keep it in the closed position. Behind it was a clay tile lined space, only about 15" high, by at least 17' deep and probably 15' wide.
homnspector Posted May 17, 2006 Report Posted May 17, 2006 Sounds like a "Central" oven system (the print on the casting was a clue). Were there more in other areas?
Brian G Posted May 17, 2006 Report Posted May 17, 2006 The little one on top is the first colonial pizza oven. The door below is for human cremation. Never do both at once, it makes the pizza taste funny. [:-yuck] Brian G. Cod Pizza Anyone? [:-sick]
