I'd guess it's the Blue Light Special, ala someone crossing the bus w/loose wire or something similar & getting lit UP.
I've had the misfortune to see what happens when someone crosses the bus up; it's quite spectacular, and could easily have done the damage shown in you picture.
There was some scorching on insulation and outer jackets of the wiring, but really not too bad, like maybe a small short lived fire in the panel.
Wierd thing is it was on every breaker tab or whatever they are called. Almost like somebody shoved the dead front in against the bus.
That's what I was driving at. It it was on all lugs suggesting a "track", lighting just might be the source.
A flash fire could not get hot enough fast enough to melt metal in that fashion.
Either lightning or some form os shorting like Kurt has suggested.
Those are my guesses.
Yup, and a fire hot enough to melt steel would have melted all of the insulation off the wiring and would have affected all of the buss metal, not just the ends like that. The buss tines would have probably held their shape and merely drooped.
And, come to think of it, if it's what Kurt suggests, I sure hope the poor fella survived...
