jeffrey8902 Posted April 20, 2006 Report Posted April 20, 2006 Anyone know where I can oder or find these? The ones I did find were very expensive. Thanks
mgbinspect Posted April 20, 2006 Report Posted April 20, 2006 When I used to probe drain fields for a relocation company I simply made one out of metal dowel from Home Depot. Boy, was that a long time ago. I disclaim them now.
MMustola Posted April 21, 2006 Report Posted April 21, 2006 Try this company. It think it is called D&T Tools. I may have the name wrong but the number is correct. Their number is 800-521-6893. They have a catalog with all types of septic system tools.
Jim Katen Posted April 21, 2006 Report Posted April 21, 2006 Around here you can find them by the barrel at any plumbing supply house. - Jim Katen, Oregon
Les Posted April 21, 2006 Report Posted April 21, 2006 Mark, Remember the inspector in your area that used to check septic fields by flushing a 1/2lb of blue dye down the stool, then running a zillion gallons of water, put on his golf shoes and then a pair of white socks over the shoes and walking around the yard writing notes about how blue his socks were? I don't think he is around anymore!
MMustola Posted April 21, 2006 Report Posted April 21, 2006 He's out of business now Les, thank god. He also checked heat exchangers by punching a hole in the duct above the furnace and used a garden spayer to soak the heat exchager, then he looked for water bleeding through cracks.
