Danube Posted February 2, 2004 Report Posted February 2, 2004 I'm having trouble removing an old tub drain. There is one cross piece inside, but I can't get enough leverage to turn it out. Should I heat it with a torch to loosen it, or is there a special tool I need? Thanks, Dan
n/a27 Posted February 4, 2004 Report Posted February 4, 2004 Dan, Sounds like you provide pretty comprehensive inspection service..lol. I used to remodel kitchens and baths and often resorted to the following techniques, not necessarily in the order given: Use the handles of a channel lock pliers inserted into the drain and try turning with another channel locks. Use a sawzall to cut a 1/2" piece out of the flange (two vertical cuts). Use a chisel and hammer to turn it out, first striking perpendicular to create a bite mark. Decide the tub should be changed and use a sledge. Good Luck!!
