Kristie Brown Posted July 9 Report Share Posted July 9 My client had an inspection done and the inspector noted the following in the roof section: The shingles are touching stucco siding in various areas around the home. When we questioned the roofing company that recently installed the roof he said... "There is a flashing behind the stucco, and under the shingles, and the shingles are installed as close to the walls as possible. The shingles touching the wall should not have any issue in the future. The shingles have to be installed tight as they can for prevention of leaks.” Is this the proper way to do this? Should we accept this or is there a differnet manufacturer install requirement with shingles? Is this going to be an issue later? thx! Link to comment Share on other sites More sharing options...
