Jim Baird Posted June 11 Report Share Posted June 11 This jacket was installed by a handyman, I guess. I don't think it was for insulation. 2 Link to comment Share on other sites More sharing options...
Les Posted June 12 Report Share Posted June 12 they left the top open to allow excess heat to escape! 1 Link to comment Share on other sites More sharing options...
Bill Kibbel Posted June 15 Report Share Posted June 15 Looks like maybe it had a shorter one originally that was fully enclosed and they couldn't find a shorty replacement. Also looks like a gopher popped up from a hole. 1 Link to comment Share on other sites More sharing options...
Steven Jones Posted July 3 Report Share Posted July 3 It sounds like you're talking about some kind of jacket or covering installed around a pipe or water heater. Let's go through the possible scenarios and what you might need to do about it. Identifying the Purpose of the Jacket Pipe Insulation: Typically, insulation jackets for pipes are used to prevent heat loss in hot water pipes or to prevent freezing in cold climates. They’re usually made of foam or fibreglass. Water Heater Jacket: These are designed to improve the energy efficiency of a water heater by reducing standby heat loss. They are usually made of insulating materials like fibreglass or reflective foil. Soundproofing: Sometimes, jackets are used to reduce noise from pipes, particularly in plumbing systems with high water pressure or in noisy areas. Protective Covering: In some cases, jackets might be installed to protect pipes or equipment from physical damage or exposure to the elements. Assessing the Installation Since you mentioned that it was installed by a handyman and you're unsure of its purpose, here are a few steps to help you assess the situation: Material Check: Inspect the jacket's material. If it’s foam, fibreglass, or reflective, it’s likely meant for insulation. If it’s a hard or protective material, it could be for physical protection. Condition: Check the condition of the jacket. Is it properly fitted and in good shape, or does it look makeshift or damaged? A poorly installed jacket may not serve its intended purpose effectively. Location and Purpose: Identify what the jacket is covering. Is it a hot water pipe, cold water pipe, or a water heater? Knowing what it’s protecting can give you a clue about its purpose. Actions to Take Consult a Professional: Given that the installation was done by a handyman and you're uncertain about its purpose, it’s a good idea to consult a professional plumber. link removed They can assess whether the jacket is necessary and if it’s properly installed. Replace if Necessary: If the jacket is damaged, improperly installed, or not serving its intended purpose, it might be best to replace it with the appropriate insulation or protective covering. Proper insulation can save energy and prevent damage. Check Local Codes: Ensure that any insulation or protective measures comply with local building codes and standards. This is particularly important for insulation around hot water heaters and pipes. Final Thoughts The jacket might have been installed with good intentions, but without knowing its purpose, it’s difficult to determine its effectiveness. A professional plumber can provide a thorough evaluation and recommend the best course of action. Proper insulation and protection of your plumbing systems are crucial for efficiency and longevity, so it’s worth getting it right. Link to comment Share on other sites More sharing options...
Jim Katen Posted Thursday at 02:44 AM Report Share Posted Thursday at 02:44 AM What a fucking moron. Can I say that? 3 Link to comment Share on other sites More sharing options...
