Mike Lamb Posted August 30, 2023 Report Share Posted August 30, 2023 Is there a legit coded requirement that hose bibs be installed at the front and back of residential housing? Or is it required that any hose bibs needs to be installed at all? I am finding a recommended reference from American Legal Library but I don't know who they are or what jurisdiction they have if any. 1102.03 PLUMBING CODE REQUIREMENT. The following provisions, to be added to the OBOA/CABO One, Two and Three Family Dwelling Code, are hereby recommended for the Seven Hills Building Code: 3100.1 RESIDENTIAL PLUMBING REQUIREMENTS. (a) Two exterior hose bibs or sill cocks shall be installed on each residence one on front wall, one on rear wall, each provided with accessible stop cock or valve. Each hose bib or sill cock shall be protected by a listed and approved "back flow preventer" or vacuum breaker to prevent any water flow into the potable water (drinking water) supply system. Link to comment Share on other sites More sharing options...
Bill Kibbel Posted August 31, 2023 Report Share Posted August 31, 2023 I think it was added in the 2006 IRC but subsequently removed - not sure when. I suspect any reference to that requirement is now an amendment by specific state or municipality. The quote above looks like a suggestion for that amendment to the Seven Hills, OH code. Link to comment Share on other sites More sharing options...
Steven Jones Posted January 31 Report Share Posted January 31 Hose bib installation requirements vary by location, and there is no universal mandate for positioning them at the front and back of residential housing. Specific regulations for hose bibs are typically detailed in local plumbing codes or municipal ordinances. While many jurisdictions necessitate hose bibs for outdoor water use in residential buildings, the exact specifications differ, covering aspects like placement, type, or insulation requirements. To obtain precise information about hose bib regulations in your area, consult your local building department or municipal authorities for guidance on applicable codes. You may also ask for expert's advise. There are available online like on Will plumbing that you can check anytime you want. Link to comment Share on other sites More sharing options...
Les Posted January 31 Report Share Posted January 31 thanks Bill. Link to comment Share on other sites More sharing options...
Jerry Simon Posted January 31 Report Share Posted January 31 14 hours ago, Steven Jones said: You may also ask for expert's advise. There are available online like on Will plumbing that you can check anytime you want. So you advice us to ask Will plumbing for their advise? 1 Link to comment Share on other sites More sharing options...
