Mike Lamb Posted April 4, 2023 Report Posted April 4, 2023 I don't know if this is a problem or not. The interior perimeter of these thermal paned windows has a cracking plastic. None of the windows shows signs of a bad seal with fogging or moisture between the glass. Might this adversely affect the R-value? I will take any remarks. Thanks.
Les Posted April 5, 2023 Report Posted April 5, 2023 cracking plastic, in and by itself, would not affect the performance of window. I suspect it is just cosmetic. Nearly all vinyl will eventually crack. I wouldn't think the plastic does anything other than look good. 1
Jerry Simon Posted April 5, 2023 Report Posted April 5, 2023 (edited) Seen that in hundreds of sashes, though that is by far the worst. Ain't takin' kindly to UV rays, I suspect. R-value? Should one really care with a crap product like that? Edited April 5, 2023 by Jerry Simon
Tom Raymond Posted April 5, 2023 Report Posted April 5, 2023 It's a desiccant strip. It's there to absorb water vapor trapped at assembly. It appears completely desiccated. While largely cosmetic, some of the better manufacturers will warranty it. 1
Jerry Simon Posted April 5, 2023 Report Posted April 5, 2023 1 hour ago, Tom Raymond said: While largely cosmetic, some of the better manufacturers will warranty it. That may be true, but I've never seen such in a *quality* window.
