SNations Posted February 27, 2023 Report Posted February 27, 2023 Do any of you folks know if the NEC has a requirement to limit voltage drop? I sure thought that the NEC had a recommendation on voltage drop, but it wasn’t a requirement. But I can’t find that info now. Any help here is much appreciated. Steve
adair Posted February 27, 2023 Report Posted February 27, 2023 (edited) On 2/27/2023 at 1:08 AM, SNations said: Do any of you folks know if the NEC has a requirement to limit voltage drop? I sure thought that the NEC had a recommendation on voltage drop, but it wasn’t a requirement. But I can’t find that info now. Any help here is much appreciated. Steve Expand this is from the interweb w/nec branch and feeder sections cited https://electrical-engineering-portal.com/download-center/books-and-guides/electrical-engineering/voltage-drop Edited February 27, 2023 by adair
Marc Posted February 27, 2023 Report Posted February 27, 2023 On 2/27/2023 at 1:08 AM, SNations said: Do any of you folks know if the NEC has a requirement to limit voltage drop? I sure thought that the NEC had a recommendation on voltage drop, but it wasn’t a requirement. But I can’t find that info now. Any help here is much appreciated. Steve Expand Last time I checked, there was a fine print note that suggested that a properly designed wiring system would not have voltage drops in excess of 5%. There was no rule involving it. I don't have the latest cycle.
Jim Katen Posted March 4, 2023 Report Posted March 4, 2023 Barry's link pretty much sums it up. I'll only point out that these are no longer called "fine print notes," but have been changed to, "informational notes."
