We removed a window on a home as part of a remodel and were surprised to find there is no vapor barrier between the masonry work and the OSB sheathing. The home was built in early 2000s in Dallas, TX with a full stone veneer, so it’s about 5-6” thick Austin stone. How did this ever pass a building inspection?  I guess it had to, but I am surprised there is no vapor barrier behind this stone.  From what I can tell there is no mold on the visible sheathing.  In the photo the green board and black tape are covering the opening left by the window. The original OSB is visible behind the stone.
  • Like 1
I don't like to rely on luck 😬
Is this construction against code?  Or is a vapor barrier not "required" because of the full stone veneer (as apposed to thin stone veneer)?
Thanks for any and all insights.
  • Like 1
Expand
i've worked the dfw & farther markets for over 24 years
municipal inspectors will allow almost anything to pass & exercise sovereign immunity, they are not consumer protection advocates, they work for a system whose main purpose is to collect more taxes, improved property brings in much more revenue than a vacant lot
that being said, there was a long period where "code required" wrb were not required over exterior substrate sheathing of any type for any exterior cladding
glad to see you've encountered slight moisture intrusion vs. many of the props i've inspected
I don't have Text Available please call or email only
Best Regards,
Barry Adair
Owner-Professional Inspector-Moisture Analyst-Infrared Thermographer
Commercial-Residential-Construction-EIFS-Stucco-Exterior Claddings Inspections
  • TREC Professional Inspector License # 4563
  • Exterior Design Institute: EIFS-MA TX # 39
  • Texas Infrared: Level I Certified Thermographer
  • National Association of Commercial Building Inspectors & Thermographers Member ID 12011-14TX
  • NSPF Certified Pool Inspector CPI Operator CPO # 75-221486
ADAIR INSPECTION
office: 972.487.5634
e-mail: adairinspex@hotmail.com
website: http://www.adairinspection.com
  • Like 1
  • 5 months later...
Expand
I always installed a layer of 30 lb. felt paper behind our stonework, and would not ever install stone in the manner you posted here. But, this does confirm what I've been saying for years - moisture does not typically intrude much through properly installed masonry. It is usually Voids in head and bed joints that permit moisture to intrude. In this instance, stone is not very absorbent and stone mortar is typically high in cement, so moisture intrusion is not usually a big issue.
  • 1 month later...
Posted (edited)
  On 2/25/2022 at 12:37 AM, Chad Fabry said:
You're the luckiest person on Earth if there's no damage. After five years in the northeast, your house would be a compost heap.
Expand
often seen down here
known as wazwood or vertical mulch
Edited by BADAIR
  • Like 1
  • 3 weeks later...
  On 7/16/2021 at 2:27 AM, Mike Lamb said:
Code pretty much says don't let outside water get inside. You should look at the manufacturer's instructions.
Or
https://ncma.org/wp-content/uploads/2020/08/MSV_InstallationGuide_5thEd_4thPrinting.pdf
Expand
I'm not sure if I can tell from the picture if the veneer is manufactured stone or natural stone.  I'm curious if the NCMA document could be challenged when it comes to natural stone.  Either way, the practices they recommend are good in either case.   However, could someone argue that the document is intended to address manufactured stone specifically and dismiss our using it to back up reporting in the event of a natural stone application?
Expand
John, i have a Benjamin, says it's natural stone
Adhered Manufactured Stone Veneer (AMSV) would have a stucco like base atop the osb
also down here amsv is a very rare choice
  • 6 months later...
Posted (edited)
John, there is a document on installation of natural stone in an adhered method. Follows a lot of the same details as the MVMA or the NCMA-MSV guide. You can find it here.
https://duckduckgo.com/?q=adhered+natural+stone+installation+guide&atb=v314-1&ia=web
There is some misleading info regarding the way the lath is installed and its nailing pattern that does not agree with code or that of the various ASTM documents, but that is for a longer in-depth conversation.
Edited by mark parlee
