Jerry Simon Posted March 22, 2021 Report Posted March 22, 2021 Does this ring true? "It appears a domestic, storage type of hot water heater was replaced with a tankless, on-demand type of water heater. If the water supply piping about the house was originally configured to accommodate a storage type of hot water heater, and the new water heater is utilizing this original piping layout, you may find that an adequate amount of hot water will not be present in areas of the house when multiple water fixtures are in use at the same time. If this turns out to be the case—and only time will tell if it will—then you may need to replace this tankless water heater with a conventional, storage type of hot water heater."
Marc Posted March 23, 2021 Report Posted March 23, 2021 I've never heard of storage-compatible and tankless-compatible freshwater supply systems.
Jim Katen Posted March 23, 2021 Report Posted March 23, 2021 2 hours ago, Jerry Simon said: Does this ring true? It rings like bullshit. 2
