I doubt that it needs repair at all. The plastic is there to reduce the risk of corrosion underground. Above ground the copper is fine without plastic - except that it should be marked yellow every several (5?) feet. If wrapping it in tape makes you feel better, go for it. I suggest using the yellow tape, though.
