Tom Breslawski Posted March 19, 2020 Report Share Posted March 19, 2020 I inspected this townhouse today (6 units, the one I inspected was an end unit). There was no fire wall or fire separating in the attic. I've never seen this before. Is it ok? Building was built in 1974. 6 units all share a common attic. Link to comment Share on other sites More sharing options...
Jim Katen Posted March 19, 2020 Report Share Posted March 19, 2020 Was there s fire suppression system? What's with big CMU wall? Is that how the units are separated? My guess is that when the building was built, the designers and the city agreed that separation walls in the attic were unnecessary, for who-knows-what reason. Perhaps because a sprinkler system was present, or because the units were separated by masonry walls, or maybe someone just paid off the building official. 1 Link to comment Share on other sites More sharing options...
Tom Breslawski Posted March 19, 2020 Author Report Share Posted March 19, 2020 There was no fire suppression system. The CMU wall separates the units but doesn't extend into the attic. Doesn't look like there was a sprinkler system. There may have been a payoff though...... Link to comment Share on other sites More sharing options...
SNations Posted March 19, 2020 Report Share Posted March 19, 2020 This might not be so unusual. In the IBC, table 506.2 lists the allowable floor area of a building based on occupancy type and construction type. If this building is of type III construction (exterior walls built of noncombustible materials) then even without sprinklers it could have a floor area of 16,000 square feet for any type of residential occupancy. So it's not so crazy to think that back in 1974 they wouldn't have required a fire wall anywhere in this building -- if it's type III. If the exterior wall is combustible then you're down to probably a 7,000 square feet limit, and so at least one fire wall probably would have been required depending on the sizes of the units. Link to comment Share on other sites More sharing options...
Mycakers Posted March 24, 2020 Report Share Posted March 24, 2020 The town house I lived in (IL) was a 4 unit and I could walk from one end to the other from the attic. The wife was a little upset to see a padlock installed on the access shortly after I found out. They were built in 92'. Link to comment Share on other sites More sharing options...
hausdok Posted March 24, 2020 Report Share Posted March 24, 2020 Hi, You called it a town house. What are the rules? Is it part of a condominium complex with townhouse style condos? If so, who is responsible for the attic and crawlspace areas - you or the HOA? If the HOA, they have a right to padlock it and keep you out of there. You can still request access once a year to check to ensure that any vents from your home remain properly connected to their terminals at the roof, but that's about all. If you are responsible for maintenance of any part of that, find whoever has the key and demand a copy for your own use. Link to comment Share on other sites More sharing options...
Mycakers Posted March 25, 2020 Report Share Posted March 25, 2020 I don't know who was responsible for the attic. My dryer stopped drying so I checked the vent. It was packed solid with lint. I went up in the attic to remove the vent and clear it. That is when I noticed the lack of fire walls. At the time I had no idea that I would want to be a HI so I didn't think about anything other than security. I am the one who padlocked the access. Link to comment Share on other sites More sharing options...
hausdok Posted March 25, 2020 Report Share Posted March 25, 2020 Hi, Around here (Seattle region) it's very common not to find any fire separation above condos from the 70's that share attics. It seems like those didn't come into common use here until the late 80's or so. ONE TEAM - ONE FIGHT!!! Mike Link to comment Share on other sites More sharing options...
