Is plastic sheeting a termite barrier?
Bobby Jim
Nope, also a pine 2x4 or whatever dimension installed flat does not make an adequate support beam, either.
The rotten joist will continue to rot, should have been removed, probably. Are we supposed to believe the termites have moved out?
What about the moisture that lead to that mess? Was that issue solved?
  • Thanks 1
20 hours ago, Bobby Jim said:
I inspected a building with plastic sheeting being used as a termite barrier on newly added piers. Is this acceptable?
Hell no.
Termites will chew through that plastic like a puppy chewing through a new carpet.
Does anything work as a termite barrier in your area? Around here, they just go around whatever barrier we put up.
  • Thanks 1
  • 2 weeks later...
