excalibur Posted February 7, 2006 Report Posted February 7, 2006 Ok guys . I have detected in one of my building inspection , today, that the concrete slab , of the building basement had a distance of 3 inches 1/2 with the foundation walls. Granular capillary was observed with a good amount of high humidity level and the presence of pluvial water contact.I told my client that this situation was not proper to building code. That this high risk oh humdity could bring important problems to the interior finished walls and components. Soil gaz could infiltrate the living space and bring some important health problems. Another **amazing home agent**[:-bigeyes called his contractor and he told me that this situation was normal ,that in this area it is a common thing to do . Regardless what he said , i told my client that concrete slab should have a soil gaz barrier and continuous around edge of slab , be in contact with the concrete walls and be sealed to wall with flexible sealant. What i would like to know is ....anyone out there have seen this situation and if yes , what do you think about it ? Thanks .. Sorry for the mistakes ...P.S. The mold picture is one of the basement wall that was covered with gyps and should have the same concrete slab installation. Download Attachment: concrete slab space 1.jpg 79.73 KB Download Attachment: concrete slabe space 2.jpg 71.46 KB Download Attachment: concrete slab space 3.jpg 68.04 KB Download Attachment: great molds.jpg 57.58 KB Download Attachment: soil gaz barrier.doc 54.76 KB
hausdok Posted February 7, 2006 Report Posted February 7, 2006 Hi, How old was the home and did you check with the local officials to see what is required in your area? ONE TEAM - ONE FIGHT!!! Mike
Darren Posted February 7, 2006 Report Posted February 7, 2006 Around here (Northern NJ) we have a 'floating' slab; the gap between the slab & wall is about 1 inch. One of the reasons for the gap is if there is water entry thru the wall; it usually does not reach the slab, it will get caught in the gap and (hopefully) run to the sump. If a high level of radon is found, they fill the gap with a backer rod & caulk. In your case, the first problem is the wood forms are still in place. After removing the forms, your gonna have 4 1/2 inch gap. The good news is if they put a french drain in, there's less concrete to take out of the basement. Darren
Terence McCann Posted February 7, 2006 Report Posted February 7, 2006 Just a quick side note. Go to http://www.iespell.com/ and download and install the free spell checker. You can run this before you post to help catch errors. Also, if after posting you see errors or typos, you can click the "edit" icon above your post to clean it up.
Scottpat Posted February 7, 2006 Report Posted February 7, 2006 What the heck is Granular capillary ?
Jack Ahern Posted February 7, 2006 Report Posted February 7, 2006 I've never seen floating slabs in my area. Wood forms and moisture = termites Spaces between floor and wall could admit critters and radon Remove form tie (rod)--trip and scrape hazard Indoor air quality issues (mold)is refered out[:-banghea Jack Ahern Needham on the Charles Bridgton,Maine
excalibur Posted February 7, 2006 Author Report Posted February 7, 2006 Sorry for the mistakes guys but i'm trying .. i'm french . This building was constructed in 1995 . I have called the city inspector and they told me that they've nerver heard of this type of installation. They seemed worried when i told them that the building contractor made multiple home like this one in the neighbourhood. Scott granular capillary is a break and drainage pad under the entire foundation slab. ( break and drainage/barrier)Thanks Terry for the tips on the english correction !
hausdok Posted February 7, 2006 Report Posted February 7, 2006 Hi, If you normally write your reports in French don't be too concerned about the spelling on this board. We'll understand. The iespell checker will definitely help you though and the more you practice the better you'll get. ONE TEAM - ONE FIGHT!!! Mike
Terence McCann Posted February 7, 2006 Report Posted February 7, 2006 I'll bet a paycheck that your English is much better than my French!
