Hi Brian,
Yeah, that happened on a Navy base about 6 years ago. If you search the archives on the ASHI board, you may find a few posts I wrote about this issue if they've saved the archives.
OT - OF!!!
M.
  Quote
If you suspect hydrogen gas may have built up in the hot-water system, flush it by turning on all hot-water faucets in the building and letting them run for several minutes. And don't smoke while you're doing it. Make it a habit of doing this every time you inspect a building. If you live in the home and are away for a vacation, do this every time you return home.
LOL...You mean I shouldn't be smoking inside someone's house while I'm doing an inspection?
Just how old is that article?
I understand how this could happen. I put in a new water heater a few years ago w/the brand new anode rod. The well water must have the characteristics to create the gas, because after being away for a week, the water stinks BAD.
Well, one time I was away for a month, & when I opened up the hot water tap, I got pure stinky gas for about 10 seconds; it was scary. If that stuff was contained in a water heater, kaboom!
I've heard this before, but have never run across it personally. I think the safe and wise thing to do in a vacant house is is run the hot water at the kitchen faucets awhile before starting the dishwasher. Hopefully that will dissipate any accumulated gas.
Yeah, what Paul said. Run the hot water first.
I think the likelihood is extremely small, but I believe it could happen.
I miswrote that first post; I meant to say dishwasher instead of water heater. If the amount of gas that came out my faucet would have discharged directly into a tightly closed area (dishwasher), I can see how it could go boom.
It is a good find, but credit actually goes to "Phillip" over at the JLC boards (Electric Shop), who posted it there. I don't normally post the same thing all over the place, but I may spread this around. It's amazing, unexpected, and the bretheren need to know. Exploding dishwashers....who'd a thunk it? [:-splat]
Brian G.
What's Next...Exploding Drywall? [:-boggled
