John Dirks Jr Posted September 13, 2018 Report Share Posted September 13, 2018 I have this compressor with a powerful electric motor and a compressor pump that works great. It's fixed on top of a small tank that has a few tiny pin holes in the bottom. Is there a thicker type of compound I can coat the bottom of the tank to seal the pin holes? Im sure if I seal each leak individually, more will just pop up. Thats why I like to try and coat the entire bottom with something. Transferring the motor and pump to another tank is possible but it looks like more work than I care for on this thing. Link to comment Share on other sites More sharing options...
Chad Fabry Posted September 13, 2018 Report Share Posted September 13, 2018 John, The explosive force of at least 125 PSI paired with a structurally compromised vessel that has a lot of square inches of surface area adds up to an undesirable outcome. I was filling a split rim truck tire assembly in 2001- the split rim broke at 65 PSI. The force of the resulting explosion ruined the tire cage and rocketed two, foot-long pieces of the ring through a twelve inch block wall. I am convinced that had I been filling the assembly sans cage I and a few employees would have been killed. Link to comment Share on other sites More sharing options...
