Jim Baird Posted September 11, 2018 Report Posted September 11, 2018 This "boot" is adhering to a flue pipe clearly labeled 2" clearance to combustible. Could find no label on boot. Does anyone here know this boot?
Marc Posted September 11, 2018 Report Posted September 11, 2018 I've seen them but never on a flue. See the dirt? Water pools there. The boot should not bridge two crests. It's incorrect.
Jim Baird Posted September 11, 2018 Author Report Posted September 11, 2018 That size boot has to span that much. My concern is the boot material being combustible.
Bill Kibbel Posted September 12, 2018 Report Posted September 12, 2018 Brick-red boots and some gray are silicone based, not rubber or epdm, and usually listed for high temp applications (400+F).
Jim Katen Posted September 12, 2018 Report Posted September 12, 2018 I've got one in my shop that's listed for 500 degrees F.
Jim Baird Posted September 12, 2018 Author Report Posted September 12, 2018 Thanks for the replies, guys. I guess my only question now is whether "high temp rating" qualifies as "non-combustible".
Jim Katen Posted September 13, 2018 Report Posted September 13, 2018 I'm perfectly fine with seeing a red silicone boot on a B-vent. Even at 500 degrees, it's not going to combust, just deform.
