Trent Tarter Posted July 11, 2018 Report Share Posted July 11, 2018 This place has laminate flooring at stairs with raised stair nosing installed. It creates an uneven stair tread surface and is quite annoying walking up/down stairs. Is there any code that prohibits this? Link to comment Share on other sites More sharing options...
Jim Katen Posted July 11, 2018 Report Share Posted July 11, 2018 At least some laminate flooring manufacturers make those step nosings and say to install them that way in their installation instructions. I also find them very annoying. Link to comment Share on other sites More sharing options...
Jim Baird Posted July 11, 2018 Report Share Posted July 11, 2018 ...risers are supposed to be the same height within 3/8 inch. The laminate is likely 3/8 and the nosing 3/4. I would say it is on the line of being busted, but would still call this out as a hazard. Link to comment Share on other sites More sharing options...
Jim Katen Posted July 12, 2018 Report Share Posted July 12, 2018 If it's installed on every step, then the risers will all be the same height (assuming that the carriages are cut properly). What's on the line about it? Link to comment Share on other sites More sharing options...
Chad Fabry Posted July 12, 2018 Report Share Posted July 12, 2018 Consider the installation has the same effect as slope and 3/8" on that 10-inch tread would exceed 2%. Regardless of whether it's compliant, it's a shit-ass set-up. What did the installation do to the nosing? Link to comment Share on other sites More sharing options...
ejager Posted October 9, 2018 Report Share Posted October 9, 2018 (edited) On 7/11/2018 at 6:42 PM, Jim Katen said: If it's installed on every step, then the risers will all be the same height (assuming that the carriages are cut properly). What's on the line about it? Maybe the height of the riser has been altered, now exceeding max permissible? As the carriages were probably cut for the original flooring plan, depending on the flooring types at the top and bottom of the stairway, those first and last riser measurements may now be different... I know I'm reviving a older thread but I really don't care for this nosing 'technique' for several reasons (not clean looking, my large feet have tripped on these raised edges traveling down stairs, and I typically find laminate to be quite slippery) and am hoping to find support/justification. Thanks Edited October 9, 2018 by ejager Realized how old the post was... Link to comment Share on other sites More sharing options...
Jim Katen Posted October 10, 2018 Report Share Posted October 10, 2018 If the risers are too high, then that would be wrong. Likewise, if the top and bottom steps are the wrong heights, that would be wrong, just like they are in 99% of the stairs that I look at. But these have nothing to do with the product. They have to do with misuse of the product. These are not a "technique," they're an approved, manufactured product and part of a flooring system. The manufacturer directs you to install them this way. I'm not a fan of the product either (I'm not a fan of most crappy building products out there), but I don't see them as a significant hazard. Heck, when I walk up & down stairs that are covered with plastic laminate, the little raised edges are annoying, but they do help to prevent my feet from slipping off the edge. Personally, I'd rather have them than not have them. (By the way, the lips are nowhere near 3/8", they're more like 1/8".) If you all want to orchestrate a unified rebellion against something, make it something that's truly horrid like sunken living rooms, boob lights, or, heaven forbid, stenciled inspirational quotations on walls. 1 Link to comment Share on other sites More sharing options...
AHI in AR Posted November 13, 2018 Report Share Posted November 13, 2018 On 10/9/2018 at 9:45 PM, Jim Katen said: ...If you all want to orchestrate a unified rebellion against something, make it something that's truly horrid like sunken living rooms, boob lights, or, heaven forbid, stenciled inspirational quotations on walls... OK...I'll bite. I know it's an old thread but I haven't visited in quite a while. That said, I just HAVE to know just what the horrid "boob lights" are that you refer to. Do they sag? Have some sort of stretch marks? Point in semi-random directions? Are they present in oddly mismatched pairs? Link to comment Share on other sites More sharing options...
BADAIR Posted November 13, 2018 Report Share Posted November 13, 2018 Link to comment Share on other sites More sharing options...
Tom Raymond Posted November 13, 2018 Report Share Posted November 13, 2018 Random directions you say? Link to comment Share on other sites More sharing options...
Jim Katen Posted November 13, 2018 Report Share Posted November 13, 2018 2 hours ago, AHI in AR said: OK...I'll bite. I know it's an old thread but I haven't visited in quite a while. That said, I just HAVE to know just what the horrid "boob lights" are that you refer to. Do they sag? Have some sort of stretch marks? Point in semi-random directions? Are they present in oddly mismatched pairs? Ahem. Barry posted perfect examples of the offending fixtures rendered in oiled bronze. These things seem to have appeared in the '80s (like most horrible house products) and have just about taken over the I-can't-decide-what-kind-of-fixture-I-want-but-I-have-to-install-something-so-I'll-just-install-the-cheapest-piece-of-crap-that-I-can-find niche. I'm ashamed to say that I have one installed in my very own, personal house. Every time I walk under it, I can feel my soul being sucked up into it. Link to comment Share on other sites More sharing options...
AHI in AR Posted November 13, 2018 Report Share Posted November 13, 2018 9 hours ago, Jim Katen said: I'm ashamed to say that I have one installed in my very own, personal house. Every time I walk under it, I can feel my soul being sucked up into it. I think I can help, Jim. Your problem is that you only have one but they are intended to be placed in pairs. Bad feng shui. 1 Link to comment Share on other sites More sharing options...
Erby Posted November 13, 2018 Report Share Posted November 13, 2018 This place is always good for a chuckle or two and sometimes a downright loud belly laugh! Link to comment Share on other sites More sharing options...
BADAIR Posted November 14, 2018 Report Share Posted November 14, 2018 (edited) unabashed drift i refer to such as 3b decor...usually gets their attention big box boring then there's the other side, oh so shi-shi chic trash decor i'm a "garbage is my friend" type & am not ashamed to admit it & have made numerous creations that others have wanted enough that i've let them have for the right amount of swap or $s persuasion but this tire-lite borders on hideous now i'm inspired to clean up an old set of mudders & a really damaged chandelier & think 4~8 keyless would be a better choice of luminary or maybe wrapped in rope light...any color preferences? Edited November 14, 2018 by BADAIR Link to comment Share on other sites More sharing options...
Marc Posted November 14, 2018 Report Share Posted November 14, 2018 (edited) 6 hours ago, BADAIR said: unabashed drift i refer to such as 3b decor...usually gets their attention big box boring then there's the other side, oh so shi-shi chic trash decor i'm a "garbage is my friend" type & am not ashamed to admit it & have made numerous creations that others have wanted enough that i've let them have for the right amount of swap or $s persuasion but this tire-lite borders on hideous now i'm inspired to clean up an old set of mudders & a really damaged chandelier & think 4~8 keyless would be a better choice of luminary or maybe wrapped in rope light...any color preferences? Brickwork on the ceiling? Edited November 14, 2018 by Marc Link to comment Share on other sites More sharing options...
BADAIR Posted November 15, 2018 Report Share Posted November 15, 2018 12 hours ago, Marc said: Brickwork on the ceiling? correct Marc vaulted masonry ceilings were a worldwide thing...not so much today may have something to do with the labor force Link to comment Share on other sites More sharing options...
