Poor airflow in Air conditioner
dennispalmer
First change your filter, check to see if there's more than one. Check you AC condenser and make sure is clean, if cooling coils are full of debris, clean the outside AC unit. If that does not correct airflow you may have a dirty/clogged evaporator coil that needs cleaned.
Is you HVAC system a two stage or variable speed system?
Link to comment
Share on other sites
