Marc Posted April 22, 2018 Report Share Posted April 22, 2018 (edited) A client changed their roof cover based mostly on a long term leak on an asymmetrical roof valley (bottom half is 12/12 on one side, 4/12 on the other. Top half is 12/12 on both sides). I specified a prefabbed copper flashing at the junction between the upper and lower halves because that point has three dimensions (flat flashing can't be bent to fit). Two months later, it's leaking again. Is anyone aware of any guidelines for flashing an asymmetrical valley? Thanks. Edited April 22, 2018 by Marc Link to comment Share on other sites More sharing options...
Erby Posted April 22, 2018 Report Share Posted April 22, 2018 Pictures? Sounds like water running down the steeper pitch is getting up under the shingles on the low slope, past the flashing. Consider a W flashing to eliminate that. Link to comment Share on other sites More sharing options...
Marc Posted April 22, 2018 Author Report Share Posted April 22, 2018 She'd wanted a closed valley so we applied a generous serving of Ice/Water all round with copper at the bend in the valley but to no avail. Maybe W-flashing just at the bottom where the valley is asymmetrical will do. Still open to ideas. Link to comment Share on other sites More sharing options...
Mike Lamb Posted April 23, 2018 Report Share Posted April 23, 2018 18 hours ago, Marc said: Is anyone aware of any guidelines for flashing an asymmetrical valley? Thanks. If there is such a thing I bet it would be the same as flashing a symmetrical valley with some common sense consideration of water flow. It's what's behind the shingles that matters. From memory of a roofing job I did a many years ago: After tear-off, apply an ice and water shield at each valley that goes a minimum 12 inches over each plane. At a violent water intersection which this roof has I would increase the water shield considerably. Follow with underlayment/tarpaper. No nails should be driven within 12 inches of the valley when applying shingles. Roofing cement should be used to keep the shingles down near the valley line. If it is leaking it sounds like the whole valley part of the roof will need to be redone. Link to comment Share on other sites More sharing options...
Jim Katen Posted April 23, 2018 Report Share Posted April 23, 2018 If it has a closed-cut valley, the steeper side should overlap the shallower side. Link to comment Share on other sites More sharing options...
Marc Posted April 23, 2018 Author Report Share Posted April 23, 2018 7 hours ago, Jim Katen said: If it has a closed-cut valley, the steeper side should overlap the shallower side. On the top half, where the two pitches are the same, the higher roof surface overlaps the lower one. On the bottom half, the higher pitch overlaps the lower pitch. That means the lap reverses sides midway up the valley, at the point where it changes direction. I'll take photos when I meet with the homeowner and contractor. Link to comment Share on other sites More sharing options...
Chad Fabry Posted April 23, 2018 Report Share Posted April 23, 2018 Did you clip the tops of the top shingles at 45 degrees? Link to comment Share on other sites More sharing options...
Marc Posted April 23, 2018 Author Report Share Posted April 23, 2018 He didn't. Why is that important? Never heard of it before. Link to comment Share on other sites More sharing options...
Leighton Jantz Posted April 23, 2018 Report Share Posted April 23, 2018 (edited) The 45 at the top of shingle reduces the chance of of runoff from opposing roof from running along top edge of shingle, and past metal flashing. This is most commonly done with an open valley though. Edited April 23, 2018 by Leighton Jantz Link to comment Share on other sites More sharing options...
Marc Posted April 23, 2018 Author Report Share Posted April 23, 2018 (edited) That's good to know. According to Chad's drawing, it's done for closed valleys also. Roofer is arriving tomorrow to talk then leaving for Mexico for three months, so we'll see if he's going to do something. Edited April 23, 2018 by Marc Link to comment Share on other sites More sharing options...
Chad Fabry Posted April 24, 2018 Report Share Posted April 24, 2018 Over 40 years ago, the first roof I installed leaked buckets at the closed cut valleys. It fixed it completely when I clipped the tops (like the shingle bundle instructions told me to) Link to comment Share on other sites More sharing options...
Marc Posted April 24, 2018 Author Report Share Posted April 24, 2018 Looks like I have my ammo for tomorrow. Thanks guys. Link to comment Share on other sites More sharing options...
Marc Posted April 26, 2018 Author Report Share Posted April 26, 2018 Turns out that the leak was not at the asymmetrical valley but at some roof/wall flashing on a dormer. I'm hired to replace all roof/wall flashing on the house. The house is just over 100 yrs old so this will take some time. The window trim sits on the roof deck so that has to be removed. Thanks guys. Link to comment Share on other sites More sharing options...
John Kogel Posted April 26, 2018 Report Share Posted April 26, 2018 Marc, be careful up there. Us older guys can't survive a fall from that far up. Good luck with it. Link to comment Share on other sites More sharing options...
