Daniel Dodge Posted January 15, 2018 Report Posted January 15, 2018 I have an inspection tomorrow where according to the buyer (he had his 1st inspection DEC 28 )water was raining through the house and into the main panel. I'm looking for any documentation for replacing the panel
Marc Posted January 16, 2018 Report Posted January 16, 2018 (edited) What is meant by 'documentation to replace the panel'? Do you mean the justification for replacing a panel because it rained in it? Edited January 16, 2018 by Marc
Jim Katen Posted January 16, 2018 Report Posted January 16, 2018 You can begin with NEC 110.12(C). Integrity of Electrical Equipment and Connections. Internal parts of electrical equipment, including bus bars, wiring terminals, insulators, and other surfaces, shall not be damaged or contaminated by foreign materials such as paint, plaster, cleaners, abrasives, or corrosive residues. There shall be no damaged parts that may adversely affect safe operation or mechanical strength of the equipment such as parts that are broken; bent; cut; or deteriorated by corrosion, chemical action, or overheating. You might also want to study this document: http://www.nema.org/stds/water-damaged.cfm (You'll have to create a NEMA user account, but it's not a big deal.)
Daniel Dodge Posted January 16, 2018 Author Report Posted January 16, 2018 On 1/16/2018 at 1:09 AM, Marc said: What is meant by 'documentation to replace the panel'? Do you mean the justification for replacing a panel because it rained in it? Expand Yes and if its necessary? Perfect Jim Thanks
John Kogel Posted January 17, 2018 Report Posted January 17, 2018 Take some clear pics of the rust after you get the deadfront off. Then if you post them, someone here will advise you, usually muy pronto.
Marc Posted January 17, 2018 Report Posted January 17, 2018 (edited) On 1/16/2018 at 6:24 PM, Daniel Dodge said: Yes and if its necessary? Perfect Jim Thanks Expand "There's water in the main breaker panel. Rainwater is breaching the exterior wall or roof structure somewhere and getting into the panel. It's a major issue because water and electricity do not play well together. Ask a carpenter or someone familiar with residential construction to find the leak and fix it. Do this before the next rainfall." Edited January 17, 2018 by Marc Edited to make it better...and a little funny.
Tom Raymond Posted January 17, 2018 Report Posted January 17, 2018 There's water in my panel. It's traveling inside the SEC jacket. It's either liquid water entering the meter can via the bushing, or it's condensation forming inside the cable assembly since it enters close to my heating equipment. I'm leaning towards the latter since its dripping now, and it's -5° today.
