Jerry Simon Posted October 31, 2017 Report Posted October 31, 2017 (edited) My house is wired with modern thermoplastic-covered wiring in EMT (pipe). Ceiling is roughed-in for ceiling fan. When I went to install a ceiling fan, one of the six wires coming out of the pipe arced on the sharp edge of the end of the pipe; blew the breaker. There is no extra wire here, and I can't get the damaged part of the wiring insulation out of the pipe to tape. Scissor truss above ceiling junction box, and can't (easily) access. I'm thinking of filing about the last 1" of the end of the pipe with clear silicone caulk; that will coat any areas of damaged wiring insulation. Once dry, I'm thinking this might be adequate. 'Course, I've never thought about whether or not dried silicone caulk would be a good insulator. Thoughts? Edited October 31, 2017 by Jerry Simon
Chad Fabry Posted October 31, 2017 Report Posted October 31, 2017 30 minutes ago, Tom Raymond said: It's EMT. Pull a new conductor. You're hilarious. Home inspectors are notorious for ignoring our own advice... and common sense. Put some shrink tube on it, do a Hail Mary thingy and move on.
