Mike Lamb Posted October 10, 2017 Report Share Posted October 10, 2017 I was doing some research on expansion joints at brick veneer in which the BIA (TECHNICAL NOTES on Brick Construction 18A) recommends a joint located every 20 to 25 feet depending on certain fenestrations. Then near the bottom of the notes at the opening remarks, it reads, "While most examples are for commercial structures, movement joints, although rare, also must be considered for residential structures." Why would residential construction be different? Link to comment Share on other sites More sharing options...
Jerry Simon Posted October 10, 2017 Report Share Posted October 10, 2017 Wall heights? Link to comment Share on other sites More sharing options...
Marc Posted October 10, 2017 Report Share Posted October 10, 2017 3 hours ago, Mike Lamb said: I was doing some research on expansion joints at brick veneer in which the BIA (TECHNICAL NOTES on Brick Construction 18A) recommends a joint located every 20 to 25 feet depending on certain fenestrations. Then near the bottom of the notes at the opening remarks, it reads, "While most examples are for commercial structures, movement joints, although rare, also must be considered for residential structures." Why would residential construction be different? My guess is politics. I don't know about Chicago but here in Louisiana, enforcement of resid building codes is lax. Builders are able to influence the cities and parishes that are supposed to enforce the codes and they often end up having it their way. Expansion joints take more time therefore cost the builder more so they don't want them. Same story for a lot of other stuff. I doubt a brick knows whether it's installed on a resid building or a commercial one. Link to comment Share on other sites More sharing options...
Tom Raymond Posted October 12, 2017 Report Share Posted October 12, 2017 Doors, and to a certain extent windows, often provide enough room for expansion. Plus, residential veneers are designed for aesthetics. Expansion joints aren't very pleasing to look at. Link to comment Share on other sites More sharing options...
